Thread: ECO SAVER Solar panel install
    Need some help guys, I have an Ultra frame 16 x 48 Intex pool with the 2650 gal sand filter and SWG. I'm going to use the Eco saver 20' solar panel mounted on my south facing block wall. Don't really have the room for a stand (don't want to kill the grass) and the roof is out of the question. The panel is 20'L x 30"H. I plan to mount it along the top of the wall with about a 12" kick out, think of a triangle on a verticle wall. It will be equally supported thru its overall length. Any body see a problem with this?
    I'd love all the expert feed back if possible
    Jim in So Cal
    Intex Ultra Frame 16 x 48, SWG - copper disconected, 2650 Sand filter, Intex PVC mods, Aqua Critter pool cleaner, ECO Saver Solar panels
    Re: ECO SAVER Solar panel install
    Welcome to TFP!
    Remember that those panels are heavy when full of water. As long as the wall is solid and you have good supports for the panels it will be fine, but if the wall is at all iffy you might want to try something else.
    Thank you Jason, not sure on the volume of water it holds but the tubes are small. One vendor said about 3.5 gal/min but I find that hard to believe
    Anybody have any suggestions on how to hang the panels
