Thread: Preformed Steps Blistering
    Jun 2012
    Long Island, NY
    3
    We have a 33,000 gallon, club shaped, vinyl lined, in ground pool. The shallow end is about 3ft deep and has a set of preformed steps. Iím assuming the steps are made with fiberglass and have gel coat similar to a boat hull.
    I just noticed 5 or 6 nickel sized blisters in the gel coat. They are raised areas that show some small cracks but I donít believe the pool is loosing any water. All of them are below the waterline and feel firm to the touch.
    What, if anything, should I do about this?
    22,551
    Re: Preformed Steps Blistering
    I would have a fiberglass person look at it. You probably want to have it repaired before it gets worse.
    24' x 52" Round AGP. 2hp/ľhp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
