Results 1 to 17 of 17
Thread: Is it time to change sand??
    Jan 2010
    Randleman,NC
    620
    having problem's with water staying cloudy..Had a heavy load of kid's Friday.Water turn's cloudy after a hour of swimming..My number's were all in check.I was showing about 1 on CC.I went ahead & started shocking .Kept it going Friday&Sat.Recheck'd last night .Past overnight test this morning...Current # Fc=18,cc=0,ph=7.8,Alk=100,Cya of 30..Did had 18 0z of Stab. yesterday to bump it up.My pressure is great on filter.I backwash'd again this morning no change on pressure..Pressure run's around 10-12.Have never changed sand on system.System is 8 yrs old.Wondering about channeling.How can you tell???
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Is it time to change sand??
    The only way to know is to open the top and see what it looks like, at 8 years you might have an issue, however there are many people on here that report no problems with sand in filters much longer than you have in yours.
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by Isaac-1
    My ? is what to look for when I open up.
    Butterfly's Avatar
    South Carolina
    10,045
    Maybe it just needs a good cleaning. Here's a link on how-to:
    my-sand-is-channeled-how-to-fix-it-t7626.html
    You're done SLAMing when:
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by Butterfly
    Thank You..Did run across this info right before you posted link..Will take top off today to check..Really no mood to be replacing sand out..I do agree with the plugging of pipe to keep sand out..Clarity has got better but it's not clear enough for me..Something is wrong I know that & it is'nt water.I thought maybe it was all the kid's sunsreen.But, it should have clear'd up by now.
    Jan 2010
    Randleman,NC
    620
    well,took top off.Got hose running now...Was able to take&follow down beside the wall to bottom...Was dirty..Sand look good.all loose no clumping..Taking my hand and working the sand around.Water was really milky white&some small particles of trash.
    Jan 2010
    Randleman,NC
    620
    Do you clean all junk off the top of the sand bed before closing back up???
    30,424
    Absolutely
    Jan 2010
    Randleman,NC
    620
    I got the best I could..I put it all back on..I back wash'd it for a while.So hopefully we will be good..
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by kplaster
    okay, just to be sure, you do 'rinse' for about 30 seconds after each backwash, right?
    Also note the clean filter psi. Once it rises about 25%, time to backwash again.
    Jan 2010
    Randleman,NC
    620
    O'h Yey!!!!Don't need the junk back in the pool..lol..Hopefully that did the trick..Water has been getting clear'r .But, having to run pump 24...I usually keep it set on timer for 8 hrs. at night..Never had a problem till this week..
    Jan 2010
    Randleman,NC
    620
    Thank You for the info..look's like it's coming back around.
    Jan 2010
    Randleman,NC
    620
    Well,back to cloudy again..The cleaning did help.But,everytime I have swimmer's it get cloudy..My # are all there.Been running clorine a little higher,no CC present&have been testing every other day now..Just doesn't seem to keep it clear..Now,when I backwash I just don't have the pressure going out now..Well,I'm quessing it's time to change sand out..What do you think??
    Butterfly's Avatar
    South Carolina
    10,045
    Can you post a set of test results?
    Feb 2008
    Milford, CT
    333
    Check your sand level, it should be in the manual for the filter itself. Not by weight, but actually what level the sand should come up to inside the tank.
    Mine was way off and I was having a similar issue.....the water just wouldnt clear up as nice as it usually does. Turns out I was way low on sand and after filling to correct level the water was visibly clearer in a matter of hours.
    22K IG vinyl, .5HP Northstar pump, S244T filter, AutoPilot Digital w/SC-48 cell
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by chrisexv6
    I was looking at manual& said 6 inch's from top of filter.Well,when I had it off I was wondering.It's just a little over 1/2.I have the Hayworth S-180-t.Hold's 150 lb's.So it's low..Have never add'd any to it..Never had a problem till this past month..Well,thank's for the info.Will have to grab a bag this week from the pool store.UGG,hate that place.lol..Still wondering if it would be better just to replace out sand since I'm in there???
    Jan 2010
    Randleman,NC
    620
    Add'd a bag this morning.I'm 7in from top of filter now.Not going to bother over another bag to get another inch.Will see how it goes.Thank's again chrisexv6 again for the suggestion.
