Thread: 0 CYA
    Jul 2011
    Brookfield, WI
    131
    0 CYA
    Greetings,
    Summer is upon us and I have been taking care of our pool so we can all enjoy a good season.
    I shocked the pool on June 13th and got it to a level of 30ppm. Our weather has been rather dry until last night, so I added water to the pool a few days ago, hence the shocking.
    I just tested the pool this morning and I have 0 FC. It did not even turn slightly pink when added the reagent. I tested the CYA and it was clear as day light. So, I need to add some of Cyanuric acid and then chlorine.
    Question: I checked the calculator and it says to add about 275oz of acid. I also need to add chlorine. In which order shall I add then? Is it ok to add then both in the same day/time?
    PH is a bit higher, but I believe that the acid will lower it, correct?
    The water is not cloudy or anything.
    Thanks. Be well
    Miriam
    20 x 44 in-ground vinyl
    Hayward Pro-Series High-rate sand filter (S310T)
    Nature2 Zodiac chlorinator
    Re: 0 CYA
    Not at literally the same moment, but fine to add them a few minutes apart.
    Jul 2011
    Brookfield, WI
    131
    Re: 0 CYA
    Thanks. I have about 6lbs of acid and probably will need to use it all. Should I dilute in a bucket first or add it directly to the pool? It has been a long time since I last add that.
    Re: 0 CYA
    Add muriatic acid by pouring it slowly in front of a return jet while the pump is running. Add cyanuric acid by putting it in a sock and putting the sock in the skimmer.
