Results 1 to 13 of 13
Thread: Min time for OCLT
    Jul 2008
    Seacoast, NH
    250
    Min time for OCLT
    Is there a min period of time for the OCLT? I tried to do the test last night. I set my alarm for 5 am, which is dawn,and woke up with no memory of my alarm having gone off at all. I did the test then and FC had dropped 3.5.
    I kept the pool at shock level today and took a sample at 9:30 pm. I'm going to try to get up at 5 to try again, but I am not hopeful. DH has narcolepsy and I have sleep apnea, so walking up is not our strong suit. If I test now (3.5 hours after the starting point) will any useful information be gained.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Min time for OCLT
    If you lose FC in 3.5 hours without sunlight on it, it will tell you that you'll lose a lot more before sunrise.
    If you don't lose anything, it doesn't mean that you won't lose anything before the sun hits the water, only that it's not enough to measure yet.
    PS: If you lost a bunch of FC, you can get a jump start on the shock process by dumping the bleach in tonight, so it has several hours to work on the algae before the sun starts degrading it.
    Jul 2008
    Seacoast, NH
    250
    Headed out to test chlorine. <yawn>
    1.5 HP Pump
    Jun 2010
    Glendale, CA
    513
    The point of the test is to eliminate sunlight as one potential source of chlorine loss. If your pool has only received a couple hours of early morning sun - that is not going to throw the test way off. Put another way - testing at 6.30am should yield a valid result. If it was later in the day (full sun) it will throw the test off by some unknown amount.
    It sounds like you did the test in the morning and had lost 3.5ppm (which is a lot) - so you still need to shock.
    I wouldn't stress too much setting an alarm for the morning. Keep shocking and testing - at some point you will see your overnight chlorine loss drop off.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    lightningguy brings up a good point, so if the sun hadn't spent much time on the pool before you did your test yesterday, then you definitely need to shock.
    Post your 3.5 hour test, if you are still awake.
    Jul 2008
    Seacoast, NH
    250
    I did shock all day.
    Results from 9:30
    FC. 14.5
    CC 0
    pH 7.8
    TA 95
    cYA 40. (working on getting that up)
    Test at 1:15 am
    FC 14.5
    CC 0
    1.5 HP Pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Well test again in the morning when you get up and lets see where you are.
    Jul 2008
    Seacoast, NH
    250
    At 10 this morning, FC was 14, cc was 0. Passed. Yay.
    just Added 2 lbs more cya now.
    1.5 HP Pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    You have mentioned that you have passed two of the criteria, what about the third, is your water crystal clear?
    Jul 2008
    Seacoast, NH
    250
    Yes, it is.
    1.5 HP Pump
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Excellant, nice job now go do some swimming
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by linen
    Does the FC need to drop to 10ppm first or can the pool be used as is?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Our recommendation for swimming is when the FC is below shock level, so for 40 ppm cya, that would be below 15ppm (per poolcalculator).
