Results 1 to 16 of 16
Thread: newbie...questions on algae, filters, and water chemistry
    stumbled on this site as I was trying to get rid of some green algae. Think I finally got rid of it by listening to what was said here. the pool is 14 months old. so here are my questions
    - how do I know that the algae is gone?
    - the bands on the cartridge filter are loose, do I need to try and reattach them or can I remove them?
    - if i use bleach in place of chlorine tablets will I have to add bleach daily, every few days, etc?
    - below you will see that my cya, and pho are high, what do I need to do
    my water chemistry is as follows it was perfomred at leslies
    fac-10 (still high from shocking the algae)
    tac-10
    CH-250
    cya-110
    ta-80
    ph-7.4
    tds-800
    pho-200
    appreciate everyones time.........Joe
    pool was built in 5/11, in ground 37,000 gallon concrete/plaster pebble sheen finish. STA-RITE system 3 Cartridge filter 400sqft filtration area, .288 gpm/sqft, 115 gpm flow rate. also has a Nature 2 mineral sanitizer and a 1hp sta-rite pump
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: newbie...questions on algae, filters, and water chemistr
    Welcome to the forum!! Answers in red below....
    Quote Originally Posted by jws13
    Perform the OCLT (instructions here). Basically, the only two things that "consume" chlorine are sunlight/UV rays and organics. By doing the OCLT, you eliminate sunlight as a possible cause
    - the bands on the cartridge filter are loose, do I need to try and reattach them or can I remove them?I have a sand filter, so I'll defer to someone else with a little more cartridge knowledge
    - if i use bleach in place of chlorine tablets will I have to add bleach daily, every few days, etc?Depends on the pool. I have a low bather load, and I'm running my CYA a little high, so I lose about 1ppm, maybe a little more, every day. I can get away with only adding bleach every two or three days. HOWEVER, I would not advise doing that until you get to know your pool
    - below you will see that my cya, and pho are high, what do I need to do Ignore phosphates. If you properly chlorinate the pool, algae can't live in it, no matter how high the phosphates are. As for CYA, the only way to lower it is by draining and replacing the water
    38,235
    Agree with the above.
    And want to highly suggest ordering one of the recommended test kits and not relying on the pool store.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Joe
    Others have beat me to the punch, but here is my take...
    The shocking process taught here has three criteria to know when you are done and have removed the algae...it is repeated in red in my signature.
    If the filters are in good shape, some folks have hot glued the bands back together. See: http://www.troublefreepool.com/how-t...65.html#p88591
    Most likely daily, though with low bather load, low organic load, and if you do not get much sun on the pool, you might be able to go longer.
    The cya is troubling and most likely higher than listed, since most tests only go up to 100 ppm. You are going to need to do a partial drain/refill. Don't worry about phosphates, if a pool has the proper FC level at all times, phosphates can be very high and not cause a problem.
    Probably the most important thing you can do next is to get an appropriate test kit. Pool stores are notoriously unreliable...especially for cya which is very important to know in order to determine your appropriate FC level needed. Since their numbers suggest you need to reduce yours, I would get an appropriate test kit and confirm for yourself. See the link in my sig for test kits.
    so while I am waiting for my new test kit to arrive should I go ahead and remove and replace some of the water? if yes, any is there anyway to determine how much I should remove? Can I use my pool pums to remove teh water, there are some hose bib valves on the piping by the pumps? also is FC and FAC the same thing
    Aug 2010
    Dallas, TX
    4,052
    poolcalculator.com will tell you how much to remove. I'm guessing at least half is going to have to go. Safer to do it in stages. FC and FAC are the same thing.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    How did you get the cya number in your first post? I am assuming either pool store or test strips. Since either of those tests have a history of being unreliable, all we can do i guess that it is high due to your puck usage. Occasionally, people have drained/refilled and found that the didn't need to do nearly as much as they thought after testing cya themselves. You will have to decide if you want to wait or not.
    Yes, especially if you have a floor drain.
    Yes
    Guess I'll wait until the test kit gets here so I can determine how much water I need to drain. Appreciate everyones assistance and I hope I am not over doing it with the questions, because I have a few more
    - have you all found it cheaper to use bleach vs the chlorine pucks?
    - is there a place to get bleach in bulk?
    - i know it will depend on chemistry and usage, but I was wondering if anyone had an estimate of how much bleach I would have to add weekly to this 37,000 gallon pool with a low number of users and frequency
    - if I am reading the info right CYA comes from the chlorine pucks, is that correct?
    - if CYA comes from the pucks will it remain pretty constant if you use bleach?
    - does cya come from any other sources?
    38,235
    Depends if you need the extra CYA in the pucks
    Sams/Costco or just the Walmart brand
    Typical use is say 3ppm/day ... that is 230oz of 6% per day for your pool size
    Or any form of dichlor and trichlor
    CYA typically only goes down from water replacement ... and some people find it drops over the winter in a closed pool
    Dichlor or Trichlor. And of course stabilzer/conditioner which is the cyanuric acid
    Smykowski's Avatar
    Sep 2011
    3,065
    No worries, keep them coming.
    Everyone was new here once. After the success I've had using the methods taught here, I will gladly spend time helping convert others.
    received my testing kit today and have started the shocking process after repalacing approx 50% of the water to reduce the CYA. My question is on the cya test. when you are looking down at the tube and the black dot at the bottom are you suppose to keep adding the water mixture until you cannot see anymore of the black dot? also does the distance you hold the tube from your eyes matter?
    38,235
    Distance and lighting matter for the CYA test. Look at the extended test instructions sticky in the testing forum for more details on how to do the test.
    ok so my cya is down to 50-60 and my FC started at 14 and is down to 10-11 (maintaining) and the cc started at 1 and is down to .25 or 0. so based on the charts it looks like I am headed in the right dircetion and oh yeah the pool water is clearing up and I am cleaning the filter cartridges everyday. Also have another question....I have not converted to bleach yet, so I still have the chlorine tablet device and I was wondering what setting it should be at during the shock process
    30,395
    You are adding more CYA back to your pool. Shut off the device and take the tablets out...permanently for now.
    38,235
    You have to stop using the tablets or your CYA is going to get too high again.you are already at the top of the recommended range.
    OK, switched to bleach last night, water is getting much clearer. Is the little bit of green I am seeing on my filter dead algae? should I soak my filter as per the commets in teh filter section or will the high levels of FC and my everyday cleaning do the job?
