Thread: Solar heater won't turn off at preset temp...
    Oct 2011
    Orlando, FL
    77
    Hi everyone:
    I've not had any problems with my GL-235 Goldline control system until now. I have my pool set at 90, and for years, once that is satisfied, the Goldline tells my pump to shut off, and it has without fail, until now.
    For the past couple of days, it heats to 91 or even 92 and the pump keeps running (and the valve actuator is sending water to the panels). For grins, I dialed it down to 85 while it was running, and it shut off. But, it starts back up again after a while.
    The whole system is so simple, I know, but I am scratching my head as to where to look. The sensors? I could do resistance checks but that seems to be a failproof part. The relay? Such a simple device. The actual board going bad on the GL-235 perhaps? I don't know how to diagnose that.
    Any help would be appreciated!
    Mike
    Mike
    9500 gallon plaster/gunite pool w/waterfall, 1/2 HP 1sp pump, 120 sq-ft Cartridge Filter, 336 sq-ft EPDM Solar Panels, CPSC16 SWG, Boratized
    38,262
    Re: Solar heater won't turn off at preset temp...
    I am guessing sensor. Check the wire and the connections for corrosion.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    22,544
    I agree with JB, it's possibly the sensor, but it could be a bad connection of the sensor wiring. The result would be the same.
    Oct 2011
    Orlando, FL
    77
    Water temp sensor, not the collector sensor, I presume?
    Mike
    22,544
    Most likely the water temp sensor.
    Oct 2011
    Orlando, FL
    77
    Yep, I believe y'all are correct. I just measured the resistance of the water sensor, and the conversion says that there is about a five degree lower temperature than the actual temp of the pool water.
    I'm surprised a sensor can go bad.
    Thanks for the push!
    Mike
