Results 1 to 11 of 11
Thread: Algae problem after using solar cover, need help
    delete
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Algae problem after using solar cover, need help
    Hi and welcome. If you want to take control of your pool:
    1. Read Pool School
    2. Get yourself a good teats kit (TF100 would be the first choice)
    3. Stay out of pool stores
    4. Read Pool School again.
    Getting rid of algae means shocking the pool. Shock is a process that takes time. You don't shock by changing the setting on your SWG. Spend a little time reading articles on the forum.
    You can start with http://www.troublefreepool.com/turni...sis-t4147.html
    chiefwej
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    After you read pool school and figure out HOW to shock---------you won't even use the SWCG during the process.
    Butterfly's Avatar
    South Carolina
    10,045
    ^^^ Yep, what chief & woody said ^^^
    You're done SLAMing when:
    delete
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Without knowing what your FC and CC are its hard to know what is going on in your pool. That's where a good test kit comes in. If your CC isn't .5 or less, then you know that you need to shock. There is really no such thing as a little algae. If you have any algae and you don't have the chlorine levels up to shock level, it is growing and multiplying faster than you can kill it. Things spiral out of control very quickly.
    chiefwej
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yeah in your case, hopefully it will go fast. The beauty of the shocking process is that it basically the same for all algae issues, how it differs is how long it takes (there are a few exceptions like Mustard Algae).
    Here is the link to the shocking process, it is more concise than the link you posted: http://www.troublefreepool.com/pool-...king_your_pool
    delete
    30,426
    can I do a sort of half way shock, say bring the fc to 12, would that still be effective,
    I wouldn't do that, good chance you will get a half-way result.
    Additionally it is safe to swim in pools that contain FC just slightly less than shock level so there's no real restriction.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    You can use the pool up to and including shock level.
    chiefwej
    delete
