Thread: Chlorine Injector, Pucks vs Liquid
    rwrogers11's Avatar
    Apr 2011
    Katy, Tx
    66
    I currently have a Hasa Liquid Chlorine injector, but see that the inline puck injectors have really come down in price. So I'm just wondering which is cheaper, pucks vs liquid, and the pros vs cons for each.
    Richard
    Pool - 18' Doughboy Above Ground Vinyl, 7600 Gallons, 1HP Hayward Power-Flo Matrix pump, Hayward Star Clear Cartridge Filter C500 50 GPM flow rate, Hasa Chlorine Injector, Pool Rover Vacuum, Taylor K-2005 Testkit - Hot Tub - Artesian Pelican Bay, 550 Gallons, Ozone, Nature 2 Mineral Sanatizer, Bromine floater.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Re: Chlorine Injector, Pucks vs Liquid
    The problem is that for every 10 ppm chlorine you add via trichlor pucks, you also add about 6.2 ppm CYA. Say you lose 2 ppm per day. That's 14 ppm per week. And adding about 9 ppm CYA per week. 6 weeks of pucks and you're at the upper limit for CYA. Pretty soon your FC is all bound up, your water gets cloudy, some day your pool turns green and no amount of chlorine will clear it unless you start by draining.
    rwrogers11's Avatar
    Apr 2011
    Katy, Tx
    66
    Well then, I think I'll stay with the liquid. Thanks for the input.
    Richard
