Page 1 of 3 123 LastLast
Results 1 to 20 of 54
Thread: Do something or just wait
    Jun 2012
    Cinnaminson NJ
    102
    Did aa treatment yesterday and added 2 quarts proteams metal magic. Pool clear and stain free this afternoon so i added algaeside as treatment suggests. Pool went cloudy in minutes. Here are my latest test results with my tf-100:
    Chlorine all 0 (due to aa treatment)
    Ph raised to 7.2 as of half hr ago
    Cya 40
    Akl 180
    I know I can't do too much with chlorine so close to the aa treatment but i will keep pucks in skimmer. But as far as the super cloudy pool I should what? Just run filter? When should I start adding some Dichlor a little bit at a time. This is why alot of people don't test water when it looks good, I know I needed to add algaeside but in hindsight wouldn't have if I would have seen these results. Just run filter or throw in some clarifier? I don't know what to do.
    Southern NJ, 1 HP Haward Pump, 16x 32 dimensions, 21,000 gallon vinyl liner inground pool, TF-100 test kit.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Do something or just wait
    Cloudy after AA treatment is normal. See this thread: cloudy-water-after-ascorbic-acid-treatment-scum-slime-t33162.html
    You're done SLAMing when:
    Jun 2012
    Cinnaminson NJ
    102
    Thanks. How many days until i can start bringing up chlorine levels after aa treatment. Would I be safe to start adding a half lb of Dichlor every hr for several hrs a night starting tomorrow? If I do 2-3 lbs a night over several nights do u think ot would be too fast?
    Jun 2012
    Cinnaminson NJ
    102
    I had used 2 lbs of aa and 1.5 lbs of vitamin c. How many bags of Dichlor will it take to neutralize the aa and vitamin c as long as I put in slowly, and what is slowly?
    Butterfly's Avatar
    South Carolina
    10,045
    First, I suggest you do not use dichlor because your CYA is already 40, which is pretty much perfect for now.
    Also, based on your CYA of 40, I suggest you add about 3 or 4 ppm FC using bleach/liquid chlorine. After the addition, circ about half an hour, retest and adjust back to 3 or 4 ppm FC. I don't know how many bleach/liquid chlorine additions/applications it will take to 'ease' into the FC level, but you don't want to overshoot the FC and cause a problem with the metals wanting to rear their ugly heads again.
    As you slowly raise the chlorine, watch for stains starting to form. If you see stains, make sure the ph is no higher than 7.2, and add more sequestering agent.
    Jun 2012
    Cinnaminson NJ
    102
    When u say liquid chlorine do u mean bleach?
    Jun 2012
    Cinnaminson NJ
    102
    I'm sorry, u did say that. I'll try to figure out on pool calculator and send what I think it'll be.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Bobswe
    Well, bleach is our regular 6% plain household bleach and liquid chlorine is the stronger version, maybe up to 12% of the same thing - sodium hypochlorite.
    Jun 2012
    Cinnaminson NJ
    102
    So are you reccomending the household bleach at 6 percent which would be 131 oz to raise fc to 3ppm. Where would I get liquid chlorine, pool store?
    Butterfly's Avatar
    South Carolina
    10,045
    Absolutely I recommend household bleach - it is the first "B" in the "BBB" method Clorox is the best, imho. Make sure it's plain and not scented.
    And yes, I get 131 oz 6% bleach to increase FC by 3ppm in your 21K gallon pool.
    ETA: yep, get liquid chlorine at pool store and sometimes big box stores, etc.
    Jun 2012
    Cinnaminson NJ
    102
    Thank you, I'm going to use bleach tomorrow night. Will use a little at a time, or should I dump the whole 141 oz in at once? And then keep testing. This should eat up some aa, and raise fc level without added cya? Thank u again for your time and expertise.
    Jun 2012
    Cinnaminson NJ
    102
    I mean 131 oz. rushing......
    Butterfly's Avatar
    South Carolina
    10,045
    Why are you waiting until tomorrow night? You can start about 24 hours after the AA treatment.
    You can add the whole 131 ozs., however, pour it very slowly in front of a deep end return. Maybe take a couple minutes for the pour. Wait about half an hour with pump running and retest. Add more bleach, same way as before, and try to reach 3 or 4 ppm. Keep at it until the FC starts holding.
    Yes, exactly correct
    Glad to help.
    Jun 2012
    Cinnaminson NJ
    102
    Ongoing question
    Merged threads to provide history to help responders. Butterfly
    I'm almost there. I've received excellent advice and think I'm on the right path. Its been 48 hours since my aa treatment and 2 quarts of proteams metal magic. I used 2 lbs of aa and 1.5 lbs of vitamin c. The pool is blue and clean liner but water very cloudy after I addded Algaeside yesterday.
    My numbers are as follows
    Chlorine 0
    CYA 40
    PH 7.2
    TA 160
    Although I normally use Dichlor to bring up chlorine level. I'm heading the advice of many that the Dichlor needed would escalate the CYA too high therefore I will be starting the bleach method tonight when the sun is off the pool. The pool calculator says I will need 131 oz of clorox bleach 6% too raise the FC from 0 to 3. I also know that I need to add this amount slowly over several minutes if not even a little slower. My main concern is that I know with the amount of ascorbic acid and vitamin c I used a few days ago will eat this up fast and I need to keep testing every hr and adding more bleach until the FC level holds at 3-4 ppm. But how many hrs and how much clorox bleach should I expect to use? If unsure and I stop a few hrs into it and restart tomorrow night would that still work. Hopefully I can get it to rise a little tonight.
    Jun 2012
    Cinnaminson NJ
    102
    I'm sorry , ta is 120.
    Jun 2012
    Cinnaminson NJ
    102
    Also, I was about to start and did a chlorine reading test and got .05 for fc and it read 1-2 on the blue box basic test kit. I've only had trichlor tabs in for past couple days. Should I go ahead and try to raise the free chlorine with the same 131 oz of Clorox? I know the goal is a 3-4 ppm reading but would be lying if I didn't say I was afraid to over do it.
    Jun 2012
    Cinnaminson NJ
    102
    Also, I was about to start and did a chlorine reading test and got .05 for cc was 4 and tc was 4.5 and it read 1-2 on the blue box basic test kit. Do these sound right? I've only had trichlor tabs in for past couple days. Should I go ahead and try to raise the free chlorine with the same 131 oz of Clorox? I know the goal is a 3-4 ppm reading but would be lying if I didn't say I was afraid to over do it.
    Butterfly's Avatar
    South Carolina
    10,045
    Hey Bob, I suggest you use the FAS/DPD test and forget the blue box OTO test for now. As long as you have that much CC , you are gonna' use up some bleach/liquid chlorine before the FC will hold.
    If you feel concerned about a 4 FC, shoot for 3 FC, but keep at it. Keep adding and filtering and testing until you get the 3 or 4 FC to hold.
    If you don't soon get the FC to 3, which is the minimum for the CYA of 40, you will start having other problems, like algae.
    Let's keep all posts concerning the AA treatment and balancing the water in this thread. It will help us help you
    Jun 2012
    Cinnaminson NJ
    102
    Ok, thanks for the reaffirmation, I'm on it tomorrow after work.
  20. Back To Top    #20
    Jun 2012
    Cinnaminson NJ
    102
    I'll be starting to raise the fc to 3-4 using bleach at 6 when the sun is not a factor. If I'm able to maintain the 3-4 ppm fc level will that help reduce the cc? I will not be able to shock for about 7-8 more days.
