Results 1 to 7 of 7
Thread: Cloudy water
    Jun 2012
    Cinnaminson NJ
    102
    Cloudy water
    Completed an aa treatment and gave a dose of 2 qaurts of proteams metal magic yesterday. Water and liner perfectly clear today what a relief, so I thought. I added 18 oz of an algaside that contains no metals and it got pool cloudy with minutes. Is that normal and can I still start raising ph immediately. How long would a cloudiness due to algaside take to start to dissipate to a clear pool again?
    Southern NJ, 1 HP Haward Pump, 16x 32 dimensions, 21,000 gallon vinyl liner inground pool, TF-100 test kit.
    Jun 2012
    Cinnaminson NJ
    102
    Re: Cloudy water
    On a side note I have a ph reading of 6.8. To slowly raise to 7.2 the pool calculater suggests about 17 lbs of borax "all natural laundry booster 20 mule team". Is that indeed correct amount? Seems like alot.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Cloudy water
    Bobswe:
    What is your TA? The amount of chemical (be it Borax, Washing Soda, or Soda Ash) needed to increase pH depends on your TA (and Borate, if any). I would test your TA and input that along with your pH into the Pool Calculator as well as the # gallons in your pool (21,000 in your case). No need to test Borate level unless you use borates; if you do, then test & input borate amount in Pool Calculator as well. I would trust the Pool Calculator calculations.
    Jun 2012
    Cinnaminson NJ
    102
    Re: Cloudy water
    Alkalinity is at 130 and I put target of all at 120. Comes up with about 14 pounds of borax of I did it right. Did I?
    Jun 2012
    Cinnaminson NJ
    102
    Re: Cloudy water
    I meant target of 120 for alkalinity, (spell check).
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Cloudy water
    Yep, I get 14 lbs of borax, too.
    21K gallons, TA 130, pH increase from 6.8 to 7.2.
    Go slow....add half to two/thirds and circ and retest and then fine tune
    You're done SLAMing when:
    Jun 2012
    Cinnaminson NJ
    102
    Re: Cloudy water
    Thanks. Added 2/3 and it's getting close. As to tge other question. How could putting in some algaside make pool go cloudy so fast. Waters blue, but milky white cloudy blue now.
