Thread: What is the purpose of brushing the pool 3 times a day....
    rogerbrks's Avatar
    Round Rock, TX
    172
    after the inital start up of a new build?
    21,200 gal IG gunite, CL 580 sqft Cartridge filter, aqua pure salt system, polaris 480-blue&white, Jandy PDA Remote, (4) Jandy Deck Jets
    Guest
    Brushiing helps remove the stuff that comes out of the plaster finish as it continues to cure. Brushing is important in ANY pool, not just new plaster, and is somethng that I bet NONE of us really do often enough. It helps keep your pool clean and mixes the water in case there are any 'dead spots' where the circulation is not as good. Even though it's a lot of work don't slack on the brushing with new plaster! It will ensure that your plater finish looks great once it's cured.
    NJ
    91
    I'm in the same stage. My PB said we should do the brushing 2x a day for at least 2 days prior to turning the heater on-to prevent the stuff from caking on the heater.
    Carolyn
    22X44 freeform gunite with DE filter (44,500 gallons), 4 deck jets
    mas985's Avatar
    Pleasanton, CA
    11,741
    Brushing is very important for a plaster pool if you want a smooth surface. If you don't get the dust off the surface, it can harden and you will have a sandpaper finish. I brushed my 3 times a day and now it is very smooth.
    Mark
    NJ
    91
    How long are you supposed to keep up with the brushing?
    Carolyn
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    I believe it was about ten days to two weeks.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
