Thread: Pressure
    lewistonpool55's Avatar
    Jun 2012
    Lewiston NY
    15
    Pressure
    My pool is cloudy with alot of dibris on the bottom. I attached my Zodiac G3 pool cleaner and the pressure in the filter is continualy going up to high causing the cleaner to stop. I backwash then rinse and it will run well for 10 minutes and the same thing happens again. HELP!
    28,000g IG
    Jacuzzi Pump and Sand Filter
    30,287
    Re: Pressure
    You are overloading the cleaner and the filter. You must manually remove all you can of the debris. The cleaner/filter is not capable of handling that much
    Jun 2012
    Lewiston NY
    15
    Re: Pressure
    Perfect! Thanks Dave. I'm a new pool owner and the site is such a big help!
    28,000g IG
