Thread: Cleaning an SWG cell
    Hello all,
    This is my first year owning a pool. Thanks to all your help I now have crystal clear water and have gotten familiar with all the equipment. One thing I wanted to do was inspect my salt cell. Given the overall neglect around the house/property, I was convinced the cell had never been cleaned. The pool is about 8 years old. However upon removal of the cell, at least to my eyes, it appeared clean, with no real evidence of scale. Should I have cleaned it anyway? Will scale be completely noticeable? Do I wait for the warning light on the Aquarite before cleaning? Is the warning light just a reminder to inspect the cell, or does it actually detect a problem? The SWG appears to be functioning normally as my FC is maintained currently around 3 ppm.
    Thanks!
    38,514
    Re: Cleaning an SWG cell
    If you did not see any scale, there is no real need to do an acid cleaning. The scale should be noticeable on metal blades as a white build up if there is any
    The inspect cell will come on about every 6 months IIRC to remind you to look at it ... this does not mean there is actually a problem.
    I would be very surprised if the cell was 8 years old ... they seem to have a typical lifespan of 3-5 years before the cell goes bad and needs replaced.
    nutjob's Avatar
    May 2011
    Dallas
    109
    Around here where the fill water is so calcium heavy such that when my daughter wakes up in the middle of the night she doesn't ask for a glass of water but instead asks for a glass of "chalk juice" the scale on the platinium plates is readily apparent.
    You can do an acid-clean if you really want to, but if there's no apparent scale and your FC readings are reasonable, it sounds like you're in the clear.
    Enjoy it!
    I laugh—to disguise the tears.
    Size 15,000 gal 510′² | Filtration DE 48′² | Sanitation SWG+O₃ | Placement in-ground (IG) | Finish pebble
    Pumps Intelliflo VS+SVRS main WhisperFlo WF-28 feature | Location Dallas TX US (33ºN 97ºW)
    Thanks for the input. It's quite possible the cell isn't as old as the pool, but I failed to mention that I also have a central water softening system at home, which is the source for my pool, so I gather this is aiding in prolonging the life of the cell. I think I will put off the acid-clean then.
    Thanks, and I love this site!
