Results 1 to 9 of 9
Thread: 3 inch cholrine tablets
    wolfy's Avatar
    May 2012
    Randleman, North Carolina
    33
    I have a 4000 gallon pool and I have the 3 inch tablets. Can I use a whole tablet or do I need to cut in half. It says tablets will treat 10,000 gallons of water and I do not want to overdo it.
    16x48 Intex Ultra frame pool with swg
    30,415
    Re: 3 inch cholrine tablets
    Do you have a chlorinator for the tabs? If not, where are you putting them?
    wolfy's Avatar
    May 2012
    33
    the skimmer?
    38,274
    Not recommended to put the pucks in the skimmer ... especially if you are not running the pump 24/7. That can be pretty hard on your equipment.
    30,415
    pump running 24/7 is not too bad, but as Jason says, when you shut that pump off for a while and then restart it, you get a big slug of chlorine through your pump....not good. Additionally, that big slug of chlorine can concentrate in your skimmer and sort of "bleed" out over the mouth of the skimmer and bleach your liner just below the skimmer.
    You should just use bleach or install a chlorinator if you're dead set on running pucks.
    22,548
    Also that slug of chlorine will have really low pH.
    wolfy's Avatar
    May 2012
    33
    Okay, trying to raise my cyan-uric acid level, I am currently at 8
    38,274
    I thought the tests start at 20 or 30ppm. How did you get 8?
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    wolfy's Avatar
    May 2012
    33
    I actually went to a pool store for a free water test. It's a new pool and I am going to buy a good water test kit of my own but still trying to get the pool up and running right now.
    test results were
    FC 1.1
    PH 7.3
    TA 28
    I am currently using SWG
    I am totally new and still learning. I plan on adding 2 lbs of baking soda, 20 more lbs of salt but I am really confused about the Cyan uric acid and what to do about that.
