Thread: Too much Borate?
    Too much Borate?
    Is it possible to add too much borates? I added borax last summer and am not sure if I should add more this summer. I have a LaMotte Insta test kit but it is very hard to tell which level the water is at. Is there another way to test for borates?
    I have a 24' round above ground pool that is algae free but very cloudy and has been for months.
    Thanks for your advice.
    Keith
    30,000 gals
    Sand Filter
    IG, Vinyl
    South Carolina
    Re: Too much Borate?
    The Lamote strips are the best borate test available, though I agree it isn't all that good.
    It is possible to get borates too high, though it takes some effort. The recommended level is 30 to 50, but anything up to 80 is alright.
    Diver's Avatar
    May 2011
    South of Boston
    450
    i thought of idea how to track borate levels and i wish i thought about it sooner..
    for non SWG outside pools CYA and borates could be kept at around the same level. meaning 40-50ppm of CYA and borates are adequate.
    since borates and CYA levels are lowered via dilution only, it means that the levels will go down to the same extend the same time. so once you have CYA and borates synched, one can monitor CYA level thru the standard test and borates levels will be the same. of course future adjustments for both CYA and borates should be the same.
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    In a SWG pool you can use salt as a proxy for borates, but there you need to keep track of salt being perhaps 60 times the borate level and add quantities accordingly.
