Results 1 to 7 of 7
Thread: Tricolor and CYA
    Tricolor and CYA
    I have a small leak and am loosing about 1" water/day. While I try to find the leak I am having trouble maintaining my CYA.
    I was thinking of switching to trichlor until I get this problem fixed. My current CYU is 10 and I opened with 8# for a 25,000 gal pool 1 month ago.
    So, how much CYA is in the tricolor?
    25,000 gal IG Utopia pool/Raypack gas heater/BBB
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: Tricolor and CYA
    There is about 60% as much CYA as Chlorine, so for every 10ppm of FC you get from Trichlor, you get 6ppm CYA.
    30,432
    I know you didn't ask but it is almost impossible to detect CYA in that range.
    The trichlor tabs will drive your pH down and will bring CYA up VERY slowly......but not with that leak
    FTWIW, you will probably never get the CYA up to any appreciable level with a leak that size. Your other parameters will be hard to maintain as well.
    Tricolor and CYA
    I know the CYA is low and just a guess. The lowering of pH doesn't concern me too much as I'm always fighting my pH as it is, and my fill water pH is greater than 8.2.
    Any advice for finding a leak?
    30,432
    Too vague to help much. Give us some more info.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    One of the problems with the internet...you took my quote at face value...and didn't detect my sarcasm...lol
    Quote Originally Posted by linen
    The leak's in the plumbing as I am getting air in my return line...it's such a hassle
    Thanks to all for great help!! Your expertice and experience are greatly appreciated!
