Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: Two week cloud
    May 2012
    Altoona, Pa
    109
    Two week cloud
    I have been passing on my new found knowledge of TFP to a neighbor of mine with an above ground pool.
    He thinks I am nuts for how much bleach he is buying.
    Here are the test results.
    24 foot round
    13,000 gallons
    100 pound sand filter
    CYA 40
    PH 7.5
    TA 140
    CH 150
    FC 16.5 (33 drops)
    CC 0
    Passed OCLT a couple of nights ago and it has been holding Free CL
    Water is cloudy.
    I looked for channelling in the sand and nothing.
    While I had the top open I thoroughly flushed the sand with water until clear.
    I added a skimmer sock and DE to filter 2 days ago no improvement.
    Could the filter be broke, I know his pressure guage is broken, but when I vacuumed there was a noticeabl reduction in return pressure. No sand in return.
    I am kinda out of suggestions unless POP is the suggestion.
    Thanks for any help.
    Johnny-M
    Altoona, Pa
    35,000 gallon in ground pool. Lazy L shaped
    Vinyl liner.
    300# sand filter
    3 Returns, 2 skimmers, and No bottom drain
    2hp pump
    Feb 2008
    Denton, TX
    5,061
    Re: Two week cloud
    Probably just needs filter time. If the returns were putting sand out, I would say that the filter, specifically a broken lateral, might be the culprit. Is he running the filter 24/7?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: Two week cloud
    That's an awfully small sized sand filter for that size pool. It's gonna take some time.
    May 2012
    Altoona, Pa
    109
    Re: Two week cloud
    Yes hasn't shut the filter off. I am keeping it at shock levels. And it has gotten better since opening but has stalled the last couple of days since the OCLT test was passed. I even got in to stir the water up and find a lost lid for a bleach bottle that dropped. I guess it will take time and patience. Unless I am mossing something.
    Johnny-M
    Altoona, Pa
    Vinyl liner.
    300# sand filter
    2hp pump
    30,403
    Re: Two week cloud
    At the very least, fix that pressure guage.....that's an important part of pool water management. Better yet, get about a #200 lb sand filter and get rid of that tiny one. (Easy to say when it's not my money )
    Jul 2011
    Mesa Arizona
    190
    Re: Two week cloud
    I had that problem a couple of months ago. All my tests look good, the water was clear but not sparkling. A very faint cloudyness to it so I added some DE to the sand filter, did the clarifier thing and about 3 days later, my water was the best it's ever been.
    My sand filter doesn't tend to get out very fine particles so it needs just a little help with that so the DE and calrifier were the ticket for me.
    Mesa Arizona. Old school 26,000 gallon in ground plaster pool with sand filter built in 1984.
    May 2012
    Altoona, Pa
    109
    Re: Two week cloud
    Dave,
    Just got my second order of refills, Thank you.
    I should probably charge my neighbor for the last order. Do you think that a 100# sand filter is too small for his 13000 gallon above ground?
    Johnny-M
    Altoona, Pa
    Vinyl liner.
    300# sand filter
    2hp pump
    30,403
    Re: Two week cloud
    Yes, probably. I would have missed that but sharp-eyed woodyp pointed it out.
    Post how many amps and at what voltage his pool pump is (or take a pic of the plate on the pump)....that the real determiner. my bet is his pump is pushing that filter too hard and even if not, a #100 lb filter is awfully small for 13k of water.
    May 2012
    Altoona, Pa
    109
    Re: Two week cloud
    I will check the amperage later on today. I know it is a 1 HP pump on the filter. The water comes flying out of the return. Maybe pushing any dead algae or fine dirt right through the filter back into the pool. Other than the DE (which may have been pushed through also) any other tricks to slow it down so it will catch more debris? I did add a skimmer sock.
    Johnny-M
    Altoona, Pa
    Vinyl liner.
    300# sand filter
    2hp pump
    May 2012
    Altoona, Pa
    109
    Re: Two week cloud
    It does catch some debris because everytime I back wash it starts cloudy then get clearer after 1 minute on BW.
    Johnny-M
    Altoona, Pa
    Vinyl liner.
    300# sand filter
    2hp pump
    May 2012
    Altoona, Pa
    109
    Re: Two week cloud
    Ok I checked his pump,
    It is a 1HP pump 60 GPM
    11 amps and 110 Voltat 6oHZ
    The filter is a Haward 100# Sand filter rated at 25 GPM
    The filter and pump have been on the pool for years, with no problems.
    It is only now that I cant clear it up that i am questioning the
    filtration system. Maybe I am nuts and need some patience.
    He wants to go back to the pool store and is losing faith in my help. HAHA!
    It has been cloudy for two weeks and a swamp before that since it was closed in October and opened in May
    Johnny-M
    Altoona, Pa
    Vinyl liner.
    300# sand filter
    2hp pump
    22,542
    Re: Two week cloud
    That 100 lb filter is definitely hampering your progress. That pump under the worse conditions is going to produce way more flow than that filter can handle. It doesn't happen to be a 2-speed does it?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Two week cloud
    Most likely that sand filter is a S116T, or something close which is a 16 in filter or about 1.4 sq. ft., so it is small since our recommended size would be at least 2.4 sq. ft. (21 inches).
    That pump also is too big for that filter, but I bet it was a packaged together?
    But if it isn't channeling, then it still should be able to clear the pool, it will just take more time.
    May 2012
    Altoona, Pa
    109
    Re: Two week cloud
    Thanks I know telling him to buy a new pump and or filter is out pf the question. Hopefully with that sock and DE it will clear up.
    Johnny-M
    Altoona, Pa
    Vinyl liner.
    300# sand filter
    2hp pump
    Jul 2010
    Philly
    332
    Re: Two week cloud
    Quote Originally Posted by Johnny-M
    Go easy on the DE. I have the same filter and it only takes a 1/2 cup to up the pressure 2 to 3 lbs. Start with a 1/4 cup. That should give you a steady pressure rise as it filters. It's easy to reach backflush pressure from the DE alone.
    Bill
    18'X4' 7600 Gal AG
    3/4 HP Pentair Pump
    Hayward S166T 100 lb sand filter
    May 2012
    Altoona, Pa
    109
    Re: Two week cloud
    Any thoughts on shutting the pump off and letting things settle to the bottom? Or using a flock or clarifier?
    Johnny-M
    Altoona, Pa
    Vinyl liner.
    300# sand filter
    2hp pump
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Re: Two week cloud
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    22,542
    Re: Two week cloud
    How long ago did you pass the OCLT (except for being clear)? If it's been more than a week You can try clarifier if you have a way to vacuum to waste. If you can't vacuum to waste Mike haas a good suggestion.
    May 2012
    Altoona, Pa
    109
    Re: Two week cloud
    It will be a week tomorrow morning that i passed the OCLT. I have had 0 CC since. You can see down to the bottom step. But not clearly and you can't make out any designs on the floor. Tested chemicals again and everything is the same as its been. I did buy another pressure guage and brought the pressure up with DE. I put the skimmer sock on and the return eye facing down towards the bottom and dumped more bleach in. It has to start clearing up gradually but how long, I dont know.
    POP??? I need some of that stuff again.
    Johnny-M
    Altoona, Pa
    Vinyl liner.
    300# sand filter
    2hp pump
  20. Back To Top    #20
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Two week cloud
    What speed are you running you pump at?
