Thread: Do you need to premix CaCl with water
    do you need to premix this with water prior to putting into pool? Or can you just spread it around in the water from the bag?
    2008 23K IG Liner, Pentair intellipump vf, 48DE filter, Heatpump, SWC, aquabot turbo T, K2006 Testkit
    Re: Do you need to premix CaCl with water
    No, in fact doing so is slightly dangerous (it gets really hot). When adding CaCl it is best to spread it across the surface of the deep end.
    Thanks for the quick responce.
    Mar 2011
    Sunny Central Florida
    91
    I premix mine. Mostly because it's humid, and some gets clumpy. It clouds the pool up more when I don't pre-mix.
    IG Plaster 20,000gal, attached spa w/ spillover, hayward C12002 cart filter, 1 1/2hp pump w/ polaris 360
    6/16/12 - PH 7.6, FC 6, CC 0, CYA 30, TA 80, Calcium 310
