Return jet pressure ok?
Jun 12, 2010
147
Levelland Texas
This may not be the thread to ask this question, but...if I may....
I have the opposite problem with my jet flow/pressure.....it is super fast!!!
We did change our sand about three years ago....we have a 1hp pump....unfortunately I have no idea what size my filter is....(I can't find that paperwork)... :x
We installed a Intex SWG this year.....but just curious if too much jet flow is bad???
BTW....the pressure gage has maintained at about 15-16 since we turned it on this season.
Please, any feedback about this is greatly appreciated!!!!
laweatherred said:
Nope no label....the measurement, right along the blue band are 65 1/2 inches....what does that tell us??
It tells us it is a 20.8 inch diameter(to the outside of the shell), so we will assume it is a 20" filter or 2.2 sq. ft.
That pump is towards the high end for that filter size, but should work. In fact, I have the 1 hp 2-speed version of your pump on a 20 inch filter and it works fine without channeling, though my plumbing will be different, so my flow may be different from yours. The flow at my return (I have a 3/4" return eyeball) is fast enough to be uncomfortable on your back if you are close to it.
