Results 1 to 17 of 17
Thread: Pump basket will not fill
    Sorry if this has been asked and answered - I looked through a couple pages and could not find the same issue. Some are close, but not the same. My pump primes ok, then fills until the about the top of the basket, then it stays there. There are no bubbles from my return. I have suspected something in the main drain might be restricting flow, but it is the same problem if I switch suction to skimmers only (which seems to be getting weaker). The pocket of air stays no matter how long I run the pump or what rpm I run at. The water level stays the same if I turn the pump off, so I don't think I have a leak around the seals.
    As far as equipment goes, I have a 1.5hp Jandy pump, Jandy DEV60 filter. I use 6lbs after backwashing - is that right? The box I buy says I should be using 9lbs. I also have a completely useless A&A floor cleaning system and a nature2 pro g plus, which I plan to replace with a simple in line chlorinator (recommendations?) - try to refrain from calling me a complete idiot for those 2 things, I am bashing myself over the head about those every year.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Pump basket will not fill
    A suction side air leak will not always cause the water level in the pump to drop when turned off. The air leak occurs only when the pump is pulling water through the line. The vacuum inside the pump basket remains and keeps the water in place. I would check drain plug and the o-rings on the pump basket lid and lube them with silicone pool lube and see if that helps. I have a similar situation that develops when the water in the skimmer is too low, or when the DE filter is dirty and needs to be broken down and cleaned.
    Love TFP? Become a
    TFP Supporter!
    Is that the drain plug on the pump? There are 2. One used to have a vacless svrs-10 breather, but it broke and I replaced it with a simple plug. If the filter needs cleaning, how intense should the cleaning be? Hose off or soak in MA (muriatic acid?)?
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    What do you mean by "simple in line chlorinator"? Liquid chlorine with no additives is the best way to go or you may end up with unmanageable CYA levels.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Jul 2009
    Houston, Texas
    9,427
    Yes, drain plug on the pump. When I break down my DE filter I hose the grids off well and flush all the old DE out of the filter body. I've never done the MA soak. FYI, never do a MA soak until after you have soaked the grids in TSP or Dishwasher detergent overnight. It will ruin the grids if you soak them in MA first.
    Love TFP? Become a
    TFP Supporter!
    By 'simple', I meant just a chlorinator with no mineral pack. In the past three years, I haven't had a problem with CYA. I try to keep it as low as possible and it always seems to be undetectable at the beginning of each season. What is the best way to introduce liquid chlorine, bleach? I guess you monitor with a test kit?
    What are your thoughts on a partial blockage? Is it time to get a Drain King?
    Jul 2009
    Houston, Texas
    9,427
    If you think that is the problem a drain king is a good way to blow out blockages.
    Love TFP? Become a
    TFP Supporter!
    If I think the blockage is in my main drain, I guess my only choice is to blow it back into the pool. Is there another way I cannot think of? I can blow the skimmers into one of the baskets easily enough.
    30,431
    What is your psi when the pump is running? A blockage on the suction side is not nearly as common as an air leak.
    When I run the pump at 2790rpm (typical), my pressure right now is 18psi. After I backwashed a couple weeks ago, it started around 13psi.
    30,431
    That psi is not indicative of a blockage. If the flow from your returns seems strong (and I bet it is) then I doubt you have a blockage but rather a suction side air leak. find that leak and your issues are over.
    I will start checking o-rings and valve fittings. Thanks so far to all those who replied.
    30,431
    Rereading your next to last post, if your psi has risen 25% or more since your last backwash, it is time to backwash again. That is completely unrelated to your issue but I wanted to mention it.
    Western Pennsylvania
    151
    OK stupid question, on mine i have air in the top of the pump basket until i open the top of the basket till the water comes up to the top then its fine, could your fix be that?
    15ft round above ground pool (6600 gallons)
    Sand filter
    Jandy gas heater
    Intermatic timer
    30,431
    Unrelated. OP has an IG pool.....priming is not the same as yours.
    I changed out the o-ring on the pump basket after lubricating just about every other one. It looks promising as there is another basket before the pump and that one was having trouble filling, but now it is full with no air bubbles. I will wait while the air presently in the system has a chance to work its way through. I think the distribution mechanism for the floor cleaner will take a while to clear out, but after that I am hoping to be ok.
    I am aware of the need for backwash. In the past, there was no problem filling the basket when I backwashed, so I did not want to think my problem was solved. I'll give it a few hours.
