Thread: New pool owner. first opening. Silly question.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    I removed the cover yesterday and started filling the pool. I've inserted the return eyes. (thats about it so far)
    Tonight I'll take out the gizmo, put the plugs back in, hook lines, etc etc.
    I want to vacuum to waste when I get the system going, question I have, is, where is the waste going? My equipment is in a poolhouse with no easy access to run a pipe out to drain/backwash. I am going to assume they plumbed a waste line, somwhere? Is there a dummy lable on the filter that will tell me what line is the waste?
    Oh, next question. My pool is a bromine pool, with brominator. Is CYA still a factor with bromine?
    Thanks, this site has been a fountain of information, and I wouldn't even have thought of attempting to open the pool myself without it.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Bromine can't be stabilized, so CYA is not something you'll deal with.
    If you have a sand or DE filter, you should have a backwash line somewhere. There should be three lines in/out of the multiport valve. One from the pump, one to the returns (possibly via chemical dispensers or heaters), and the third is the waste/backwash line.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Ok great, thanks John. Its a sand filter (Hayward) If I recall correctly, the filter valve is typical, and the other valve is labled Port 1, Port 1 & 2, Port 2. I assume that means fed by skimmer, skimmer and drain, and drain only. There is a brominator/dispenser in line, but it only appears to be a 1/2" line.
