Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: pictures finally from chandler az part time for now
    Apr 2012
    chandler az
    65
    trying to add pictures can firgure it out, pls help
    Feb 2012
    Phoenix, AZ
    728
    Re: pictures finally from chandler az part time for now
    Looks like you figured it out..but if you want to learn how to add images that are hosted somewhere else, you can check out this guide I put together.
    ttp://www.troublefreepool.com/how-to-ad ... creenshots
    PS welcome to TFP!
    Apr 2012
    Wichita Ks
    29
    Warning, lame joke ahead...
    To paraphrase a movie line, "Think you used enough pumps there Butch?"
    For those of you too young to have seen it, Robert Redford and Paul Newman in Butch cassidy and the sundance kid blowing up a safe in a train.
    23k Vinyl, Sand Filter tr60, 1hp Whisperflo pump,Coverstar autocover
    Polaris 280,K2006 kit,direct sunlight
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, dirtfrmr
    I can see your pics...and all of those pumps
    Samantha Sabrina's Avatar
    Apr 2012
    Bloomsdale, Mo
    346
    Ummmmmmmm, blonde question here, lol.
    Are you planning on having to put a fire out in that new pool?
    Nice plumbing job though. Really neat looking.
    Samantha
    In the process of building for a 22' Intex Ultra Frame, (completion date up in the air at this point).
    We could not beat our backyard into submission so we "Buried It".
    Apr 2012
    chandler az
    65
    more pics
    Apr 2012
    chandler az
    65
    last pictures
    the pumps are for
    spa
    pool
    one each for a resistance jet to swim agaisnt 2 jets
    Apr 2012
    Wichita Ks
    29
    Very nice. Swim against the pump flow and then chill in the spa.
    Is that an owl placed on the rocks?
    Guest
    Very nice pool..............we put an owl out but it doesnt seem to deter the birds from hanging around.......we actually had a dead baby bird floating in our pool today.........ewwwww
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,853
    I hope they installed a grease fitting on your electric meter! Does it dim the lights in the neighborhood when you turn on all the pumps?
    chiefwej
    Apr 2012
    chandler az
    65
    owl is behind rocks and it moves with the wind,hopefully we don't turn all of them an once,the pumps>, seems like it is very complicated system, will be interesting when i get there!
    Apr 2012
    chandler az
    65
    How or what info do I need to start to understand all of these pump handles and solar stuff? I visited last week and have come away confused with the operational side of this setup. Pool is 20,000 gallons, i have test numbers to be reported later, I thought the salt level tasted high, choroline tested at 10/10,
    but until we live there have to rely on pool guys and the current methods. I would like to have a better understanding so that we can do it ourselves. Does the addition of choroline cause the red eye condition as well when we make the switch? As usual many questions! It was enjoyable in the Phx heat. Pool Temp was 86 to 90, which is a little warm and i will have to learn how to use a solar system for cooling in the summer, thanks in advance for any suggestion.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by dirtfrmr
    What can cause eye irritation is ph (being to high or low) and/or the presence of CC (combined chlorine).
    The ph just needs to be adjusted between 7.2-7.8...we can make recommendations once you are able to post full test results.
    CC shows up when a pool has not been properly chlorinated (usually to little chlorine) and is a product of the "good" chlorine being used up killing algae.
    Bottom line, if eyes are irritated something is wrong and should be dealt with.
    Apr 2012
    chandler az
    65
    1st results from tf100 kit, I am not sure of the accuracy, but i will post anyways. My pool is 20,000 gal pebble surface, swg, solar heater and gas heater in Chandler az. Pool temperature was 85 to 90 , tasted a bit of salt, includes a spa and a water fall feature.
    cl 4
    tc 12
    ph 7.2
    ta 50
    ca hardness 1300 ?
    cya 60
    Apr 2012
    chandler az
    65
    Ok We have finally relocated to chandler AZ. I have a single speed 1.5 pentair pump that is noisy, i assume bearing failure. The solar system has blown off the relief valve and i have 3 components i have found in the yard. Although an inspection was done in May 2012, failures of A/C, Master Bath Hot water, solar sytem with blown parts, a Pentair Pump that is not far away.
    My Question is the pump? Should I repair the original pump, replace with a 2 speed or a variable speed pump? The solar we will determine, when we can get on the roof in febrary,seems as that is just pvc pumbling. A/C has been fixed and the hot water repaired.
    Pool in approximately 20,000 gallons, pumping station is shown above, everyone here says it is complicated! I firgure we should break it down and start to fix item by item. Any suggestions would be appreciated. Welcome to AZ and all the people intrusted to Help with our move. Thanks to you guys for you advice and comments in advance.
    RH
    37,391
    It has gotten pretty cold around here this winter, so the solar may not have been drained properly and thus frozen and cause the damage.
    What are all the pumps for? Which one is failing? The solution may depend on the application. Likely though you could get rid of a couple of those pumps pretty easily. And thinking ahead now may save money down the road.
    Apr 2012
    chandler az
    65
    Main pump is failing. Two pumps are for resistance swimming. The other is the spa I believe.they are all single speed. I was considering a 2 speed for the main .I have a polaris. Eos command center foe automatic control. Not sure if it all works together
    37,391
    Does the main pump also do the filtering for the spa, by an overflow or something? Is it ONLY for circulation and filtration?
    Is the spa pump ONLY for the jets, thus bypassing the filter?
    If the answer to all that is yes, then you have very low flow requirements for the main pump and could likely use a small 2-speed on low speed almost exclusively. With your automation, you may be able to run on high speed for short periods to improve skimmer, but most of the time on low speed, thus saving money on electricity. A VS does not likely make sense unless your electrical costs are high and you are able to get a rebate from the power company (Tucson does not).
    Is that a Superflo or Whisperflo?
    Apr 2012
    chandler az
    65
    whisperflo. thanks for your response. Rebates here in chandler are $50 to $200 i think haven't done that research yet.
  20. Back To Top    #20
    37,391
    What is the service factor on the 1.5 HP motor. The key is to multiply the HP by the SF to get the SFHP, that is the number you want to keep in mind.
    Also, are the pumps wired for 115V or 230V?
    Options:
    1. Replace the motor with equivalent 1 speed.
    2. Replace the motor with an equivalent 2 speed ... meaning a 1.5HP
    3. Replace motor with smaller 2-speed, but then would also need to replace the impeller. I know there are 1HP 2-speed motors.
    4. Replace the entire pump (either go smaller with a 2-speed superflo, or variable, but I think the variable does not make much sense ... UNLESS, you consider changing the plumbing to use the VS for the pool and spa. Although, it may depend on what pump is running through the heater).
    1 is the cheapest cost, but will use the most electricity.
    2 and 3 are probably pretty similar in initial cost, but 3 would save more power than 2.
    4 will cost the most up front, but MIGHT save the difference in electrical savings and MIGHT allow you to get rid of the spa pump.
    Although in fairness, you could likely get rid of the spa pump with options 1, 2 or 4. But, the plumbing may get a little odd depending on how you use the heater and how it is plumbed.
