Thread: Intelliflo and Jandy Aquapure 1400 swg
    May 2008
    NE Florida
    51
    Just curious on anyone out there with an Intelliflow VS and swg, specifically Aquapure 1400. What is the lowest RPM you've been able to run and still have enough flow to activate the swg? I just installed an Intelliflo, my swg is on a bypass that goes to a venturi skimmer. It seems to work at 1500 rmp, but after a while I'll get a service light showing on the swg but it still indicates there is flow occuring for the swg. I may have to move the swg to the main line and see if that helps make it run on a low rpm.
    22K gallon free form pebble tec pool, non screened, surrounded by 3, 100+ year old Live Oaks (pure misery for 3 months every spring) elevated non heated spa, jandy cl340 filter, Pentair Inteliflo 3hp pump, Jandy 1400 swg, infloor cleaning system which has had all outlets removed due to uselessness of system with the organic load the pool carries and now low rp
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Intelliflo and Jandy Aquapure 1400 swg
    It's going to be different in each pool, since no plumbing is identical. Trial an error is really the only way to find out, unfortunately!
    Aug 2008
    Henderson, NV
    21
    Lowest I have set is 1650, which uses about 300 watts, and do not have any flow issues.
    8000 Gallon Gunite, Standard Plaster
    Pentair 011056
    Pentair Clean&Clear Plus 420
    Rooftop Solar
