Thread: Do I need to shock?
    Do I need to shock?
    I use a TF-100 when testing, and all numbers are good... last test results are below:
    PH 7.4
    TA 80
    CH 260
    FC 2.0
    CC 0
    TC 2.0
    CYA 20
    Pool water is crystal clear, everything looks good. Found a mouse in one of the skimmer baskets. My question is this... Do I need to shock as a result, or if all the test results are ok then am I ok? Would like to be able to swim tomorrow as it's supposed to be a beautiful weekend.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Do I need to shock?
    I don't know the answer but if I shocked every time I pulled out a salamander or frog I'd have to leave it at shock level all the time!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    38,301
    Well FC is a little low anyway. You should at least bump it up a bit extra due to the animal. Do an OCLT to see if your water is clean.
    Also raising the CYA may allow you to use less FC everyday.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    22,550
    I'd bump it up to shock level and then just let it drift down to normal from there.
