Results 1 to 14 of 14
Thread: Question on PH
    Question on PH
    Since I got my test kit and testing PH/CL daily and weekly for other things I notice my PH goes up from 7.5 to 7.8 in about a week - then i add muratic acid to lower and then it rises. Thoughts?
    Numbers from 06/11
    PH 7.5
    FC 4.5
    CC 0
    TC 4.5
    TA 60
    CH 380
    CYA 45
    Today:
    PH 7.8
    FC 3.5 (SWG on 40% running on low speed for 6 hours a day - gonna bump it to 50% as I want to stay in the 4-5 range)
    CC 0
    TC 3.5
    TA 60
    CH 380
    CYA 50
    Is it normal for PH to rise that fast?
    25K gal plaster IG pool/spa - Aqua Pure SWG - Jandy RS8 with OneTouch and iAqualink - 1.5HP Jandy Variable Speed ePump - Pentair 3 HP Spa Jet - Polaris 280 with booster - Pentair Cartridge Filter - 400K BTU MiniMax Heater
    Feb 2012
    Phoenix, AZ
    728
    Re: Question on PH
    Do you have any water features? A waterfall, for example, will affect pH. High TA can also lead to rising pH...tho your TA certainly appears to be under control.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: Question on PH
    That may be perfectly normal for your pool SWG and aeration can both cause pH rise. Normally low TA helps buffer it, but at 60 you are already very low. Borates would also help buffer pH rise. But in the end you would still use as much acid, just have to add less frequently.
    chiefwej
    Re: Question on PH
    I do have a built in spa that overflows to the pool - obviously this is happening 6 hours of the day along with SWG aeration.
    So you feel this is a normal increase with these variables?
    Best course of action just a weekly does of acid?
    Thanks!
    38,251
    Re: Question on PH
    Since your TA is already on the low end ... sounds like you will just have to continue adding acid. The overflow and SWG are just going to keep raising it unfortunately.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Re: Question on PH
    thanks guys. since this is my first pool and I just received my test kit a couple weeks ago - I dont have any history or experience to compare too. So ill chalk this up as normal and report back in future test!
    Shooting for 4-5 on the FC sound about right? From what I read my CYA should be bumper with an SWG - Im just concerned that Leslie always said I had 90-100CYA and when I test is always about 50. Guess I need to learn to trust my test I even give it to my wife and tell her to fill it and she gets the same number without me telling her or her even knowing what she is testing so definitely an unbiased tester!!
    Question on PH
    A pic to show off the clear water thanks to you guys!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Question on PH
    Quote Originally Posted by Wicked
    Minimum FC level for 50 ppm cya and a swg is 2 ppm (from poolcalculator.com), so you are running a little high. CYA of 50 ppm is lower then most people run for the swg, recommended levels is 70-80 ppm for swg.
    Typically new users get higher than actual readings. You do need to trust your readings since pool stores typically get this one wrong. If it helps, here are the cya extended test kit directions: http://www.troublefreepool.com/exten...1.html#p206397
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Question on PH
    Thanks!
    Wicked:
    I also have a spa that overflows into the pool. Even with a chlorinated pool (non-SWG) my pH tends to drift up, which is normal due to the aeration provided by the waterfall. During the swim season, I target a pH of 7.5. When it hits 7.6, I add a dose of MA as calculated by the Pool Calculator to get it back to 7.5. I test pH daily, so I am administering a dose of MA 2-3 X per week. I test TA weekly and adjust if needed.
    BTW, that's some good looking clear water in your pool pic!
    RaviePoolGirl's Avatar
    Nov 2011
    Napa, CA
    47
    Re: Question on PH
    I too have a SWG and overflow from spa to pool. I have been adding 1 cup of MA daily. I don't like my pH to get up to 7.8. I try to keep between 7.5-7.7. Hard to tell what it is over 7.8 and my CH is high, so it's better to keep it lower for me.
    20,000 gal inground hourglass shape with 7' Hot Tub with overflow; Gunite
    Hayward TriStar 1.85/.22 THP - Hayward cartrige filter- SWG.
    Hayward Gas Heater
    Question on PH
    Thanks for all the information and assurance. I will continue to dose weekly with MA!
    Question on PH
    Quote Originally Posted by linen
    Good info. Quick question. The kit I got just came with a bottle with a label on it. It says fill to bottom of label with pool water then to top of label with CYA regent. Is there a more accurate measurement to be used? I.e. 7ml pool water 7ml cya agent?
    Thanks
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Question on PH
    It is 50/50 pool water/R-0013
    7ml/7ml is fine and if you cya is higher then 50 (but under 90), you can do 3.5/3.5
    Question on PH
    great - thanks!
