Page 1 of 3 123 LastLast
Results 1 to 20 of 41
Thread: Neighbor ready to jump
    Jul 2011
    Somerset, WI
    37
    Ok Im a newbie and started on this site last year when I got my pool. Got the TF-100 kit and all has been great with my pool since doing the BBB. The neighbors however not so good. He is a pool guy who loves to go to the pool store and buy all the pre-packaged stuff. Shocks, stabilizers, clarifiers, you name it. So lately I have told him about this stuff here (BBB) getting him to change. Ran tests the other day and his chlorine is at 0. He uses all the time Trichlor pucks. Tested his CYA and I get roughly 80. His PH is about 6.8. I have never dealt with stuff so out of whack. I put in yesterday 3-BIG jugs of Bleach to no avail. Chlorine still does not register. Using the k-1000 kit.
    After reading here I told him he might need to drain down a foot and then go to shock levels with bleach. Maybe an Algae bloom?? Heck really do not know. I told him to go to the pool store and buy straight chlorine (5gal jugs) buying 3 of them. Chlorine is 10.8%. thought this would be more efficient than a pile of clorox jugs to try to correct. His pool is roughly 29,000 gal. Told him to store away the pucks for now. Have no idea (being a newbie) if I should even get involved in trying to help/convert him. Am I doing this right, is my thinking right? What do I do...HELP!!
    • 29,700gal. (18x40, avg depth 5.5'), Cartridge Filter (Pentair Clean & Clear CCP420)
    • IG, Vinyl, 1 HP Pump (Pentair SuperFlo High Performance), Pentair Master Temp 250
    Blink
    brett@blinkvisuals.com
    38,251
    Re: Neighbor ready to jump
    Sounds like you have the right idea
    ... although many people are not receptive. Can you get him the come tobthe site and start reading for himself?
    I would suggest about 50% water change. Get the pH up in the low 7s. And start the shock process.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Is he really ready to jump...you description does not make me think so...may I am wrong?
    My advice would be to mention to him how you maintain your pool, he can see the results for himself, then let him come to you if he wants too. In the end, unless you are going to do all the work for him in the future, he is going to have to learn this method...although if he is receptive, you can help with that.
    Jul 2011
    Somerset, WI
    37
    Thanks! He is receptive, I have sent him a link to this site and told him to do pool school. But long and short of it is he wants my help to get this thing (pool) turned around this weekend. Any idea for a pool with 29,000 gal how much Chlorine to bring to shock level? How do I go about it? Never had to do this before. He is filling pool as I type. He only drained it down about 15inches. I know not ideal but is this workable? ...I also told him to get a case of beer
    Blink
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Use the http://www.poolcalculator.com/ to determine how much and what you need to add to the pool.
    chiefwej
    Mar 2012
    Amarillo, Texas
    341
    Shock level should be 21, but I think you need to adjust pH first. If his FC was 0 at the start of the shocking process, he would have to put 702 oz of 10.8 percent bleach to raise it to 21. Then maintain it until he passes OCLT.
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    Jul 2011
    Somerset, WI
    37
    mpacheco72, THANKS! So to bring up PH just add about a Box or two of 20-mule team Borax, or? I have his pool uncovered and jets running on high. When do I test the PH again after I dump a bunch of Borax in? Get PH at least to 7.2?
    Blink
    Mar 2012
    Amarillo, Texas
    341
    I'm not sure on the PH. I always have to lower my PH. I suggest you use the pool calculator since you will be having to check levels often.
    18'x48" AG
    Hard Plumbed
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Blink
    You need to know what the new cya level (after the drain/refill) is before you can determine what the FC level is needed for shocking.
    His PH is about 6.8
    Do you know his TA level? Borax is the best choice for raising ph, but if his TA is really low (lower than 50 ppm) then raise that first with Baking soda.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    What did his water look like before draining?
    Quote Originally Posted by linen
    His PH is about 6.8
    Jul 2011
    Somerset, WI
    37
    All of you are the best! He is running to stores now to get the goods. I will report back later tonight or in the morning on my findings. I will follow the levels in the calculator depending on my TA test and CYA test and work on PH first. I just wish that CYA test is not so subjective. Filling the tube until the dot is covered is a little bit of a **** shoot as to when it is “truly” covered. Thanks All!!!!
    Blink
    Jul 2011
    Somerset, WI
    37
    his pool looks very clear actually.
    Blink
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    What have you been getting for CC? If it is less than 0.5 ppm, then you may want to a OCLT before you go all out shocking then. See: http://www.troublefreepool.com/pool-...rnight_fc_test
    Since he let his FC drop to 0, it is likely he has organics, but lets do the OCLT to make sure. For the OCLT, I would probably raise the FC level up to shock level for his cya (since he let his FC drop to 0 and in anticipation of needing to shock anyway). Then for first (evening) test, do the test at least an hour after adding chlorine (and after the sun is off the pool). Again in the morning make sure the test is done before the sun hits the pool. Also, make sure the chlorinator is empty so that does not skew the results.
    Jul 2011
    Somerset, WI
    37
    Will do Mod Squad! Have never done the OCLT so this will be a first for me...part of my training I guess I will follow your link and perform tonight. Thanks for everyone’s help! This site is the BEST!
    ...His beer better be cold!
    Blink
    Jul 2011
    Somerset, WI
    37
    Oh Mod Squad one last thing it was recommended to get PH up first if I do that how soon after can I dump the chlorine to SHOCK and then later of course at night do the OCLT?
    Blink
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Since the ph is so low, I would like to see a TA measurement before moving on. It may take multiple adjustments to ph to get in the 7.2-7.4 recommended ph range before starting the shocking process.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I should probably add, if the TA is above 50 ppm, then just adjust ph with borax and the pump running. Retest 1 hour later and readjust until ph is 7.2-7.4. Since you are reading 6.8, it may be lower, since the test indicates 6.8 for everything lower than that.
    RaviePoolGirl's Avatar
    Nov 2011
    Napa, CA
    47
    Dumping in all the chlorine as you stated in the 1st post leads me to believe he should shock the pool. Sounds like the 3 BIG jugs were used up so quickly, you never was able to get a chlorine measurement from it.
    20,000 gal inground hourglass shape with 7' Hot Tub with overflow; Gunite
    Hayward TriStar 1.85/.22 THP - Hayward cartrige filter- SWG.
    Hayward Gas Heater
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by RaviePoolGirl
    Good point! Definitely raise up to the shock level when doing the OCLT tonight so you can get a jump on the shocking process.
  20. Back To Top    #20
    Jul 2011
    Somerset, WI
    37
    Thanks I will work on PH get that close then onto SHOCK. Then OCLT. Wish me luck! I will post tomorrow afternoon results of all.
    Blink
