Results 1 to 12 of 12
Thread: Need help with pool fill line
    Hello everyone, I recently bought a foreclosed home with a pool. This is my first pool and since the home was a foreclosure, I did not get the oppurtunity to have the previous owner show me how everything on the pool works. By reading this website, I think I have a good understanding now how the filtration system works but I have one problem that I havent been able to work out. There is a PVC pipe sticking out of the side of the pool, about a 1" diameter pipe. This pipe is just above the water line. Now I thought it was a dedicated line to fill the pool, however I cannot find anywhere to turn the water on. What is going on here? Is it possible that it was plumbed to the pool but never connected to a water source? I really do not want to start digging to find the other end of the pipe. Any ideas or suggestions would be greatly appreciated.
    Ed
    22,539
    Re: Need help with pool fill line
    Welcome to TFP.
    There's a good chance that's an overflow and not a fill line.
    If it's a fill line there should be a valve with a backflow preventer real close to it.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Welcome to TFP.
    And if it is stick a hose in it and see where the water comes out....
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    22,539
    You can try that but if it goes to a buried cistern you may not see it.
    I don't think it is an overflow line. On the other side of the pool there is a small square grate at the water line that i am sure is the overflow drain. It rained a few days ago and there was definately water draining through that grate.
    Quote Originally Posted by harleysilo
    Welcome to TFP.
    I do have a backflow preventer on the side of the house. My sprinkler system would not come on. I went to the backflow preventer and noticed the valve was in the off position. When I tried to turn the valve to the on position, the handle fell apart in my hand from rust. I assumed that backflow preventer went to the sprinkler system since the water was turned off and the sprinklers didnt come on. This may be a dumb question but is it possible for the sprinklers and the pool fill line to use the same backflow preventer?
    Ed
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Alternatively if the line fills up and starts squirting out around the hose it may mean there is a valve on the other end....
    18'x43' Sport Pool
    22,539
    Yes they can share the backflow preventer but then your fill would either have to have a separate valve or an auto fill float.
    Weird, No valves that I can find and there isnt a float anywhere. I guess I need to replace the valve on the backflow preventer and see what it does.
    Ed
    Jun 2012
    western NY
    1,559
    Any pictures you could load? I am suspecting this may simply be the filter return outlet
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Quote Originally Posted by danpik
    So what do you think?
    clw72's Avatar
    Oct 2013
    Fort Worth, TX
    66
    That looks like a fill line to me. If it's not tied into a hose bib on the house, it may be tied into your sprinkler system. Our previous house had a separate zone on the sprinkler system for the pool fill line.
    Carman
    17K gallon IG pool w/Spa, 400,000 BTU Propane Hayward Heater, StoneScapes finish w/sealed Oklahoma Flagstone coping and tanning ledge, Hayward Aquarite Salt System, 60ft D.E. filter, Hayward Tristar 2 HP 2 speed pump, Polaris 280, Pro Logic PS4 w/freeze guard. New build December 2013. Pool gets full sun.
