Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: My first conversion
    doc.mosi's Avatar
    Jun 2012
    Minnesota
    52
    My first conversion
    Alright....gonna takle a conversion this weekend. Got the test kit in hand and I'll be posting pics and results as I go.
    18ft Round Intex Metal Frame, 7000gal, 3/4HP pump, 100lb sand filter, TF-100 Test Kit, through the wall skimmer, Baqua convert...now BBB all the way. :)
    Ugly Drum Smoker (UDS), Weber One Touch gold. (I love smoky meat) :) Saving my $$ for a Big Green Egg.
    Things I use daily:
    Aug 2010
    Dallas, TX
    4,052
    Re: My first conversion
    Love baqua conversion pics!
    It sounds like you are totally prepared , but just in case you haven't already seen them, take a look at the Baqua conversion instructions in Pool School.
    doc.mosi's Avatar
    Jun 2012
    Minnesota
    52
    Okay first test:
    PH - 8.0
    TA - 330
    FC - 0 (expected value)
    Added muratic acid to lower PH to 7.5 and got the fish eye breaking the surface to aerate and hopefully lower the TA.
    Added 250 Oz of 6% Chlorox.
    Pics later...posting from my phone due to no Internet at home right now.
    Things I use daily:
    doc.mosi's Avatar
    Jun 2012
    Minnesota
    52
    Thanks for the info JL...I've read almost everything on baqua conversions on the site....
    Although I'm sure I'll have more questions as I progress.
    Things I use daily:
    doc.mosi's Avatar
    Jun 2012
    Minnesota
    52
    Third test:
    TC-12.5
    FC- 9 (zero last two times)
    CC- 3.5 (just trying out test kit)
    Added 100Oz bleach
    Will test pH and TA again next time.
    Things I use daily:
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Just make sure your ph is down 7.2-7.4 range, then stop worrying about ph and TA until you are at the end of the process. The ph test is not accurate above 10 ppm FC (it reads high), so make sure you are adjusting to a valid ph (again, taken when FC is below 10 ppm).
    doc.mosi's Avatar
    Jun 2012
    Minnesota
    52
    Thanks for the info linen
    Things I use daily:
    doc.mosi's Avatar
    Jun 2012
    Minnesota
    52
    First test today...
    FC-2 (200Oz bleach added)
    pH-7.5 (no adjustment)
    Pool is clearer today.
    But the rain is making out a pain to test and add chemicals.
    If this keeps up I won't be smoking any meat for fathers day.
    Things I use daily:
    doc.mosi's Avatar
    Jun 2012
    Minnesota
    52
    I have a question:
    When us it safe to use the pool during this process?
    I've got four kids and a wife that demand an answer from me....so far I've just said when its all done.....but is that accurate?
    I mean....pH is in range....FC its at shock level (15ppm)....is that safe to swim in or what?
    Sorry for the noob questions.
    (mods...feel free to move this to the correct forum if needed)
    Things I use daily:
    30,421
    If the pool water is clear enough to see kids safely and you are not above shock level, go swimming!
    doc.mosi's Avatar
    Jun 2012
    Minnesota
    52
    So I'm in the middle of my conversion....still shocking...FC still drops overnight and CC been hanging about 2.5 for a day or two.
    Tonight I test after sundown:
    FC - 0
    CC - 0.5 (is this test accurate with FC at 0?)
    Add bleach to bring FC up to shock.
    30mins later:
    FC - 21.5 (My pool must be a little smaller than 7500 gallons as calculations for shock always bring me above the 15ppm.)
    Just really wondering about the CC test when the FC is zero...is it accurate?
    Thanks all.
    Things I use daily:
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by doc.mosi
    Yes, you can have a CC reading without an FC reading.
    doc.mosi's Avatar
    Jun 2012
    Minnesota
    52
    Thanks linen.
    Still lost 10ppm FC last night....the process continues...gotta buy more bleach on the way home from work today.
    Things I use daily:
    If I am reading correctly, you lost about half of your FC level overnight. That means you are about half way done with the conversion. At this point it gets less efficient to add chlorine during the day. You can get the conversion done most quickly if you continue adding chlorine all the time, but you can save a significant amount of chlorine, and money, if you only add chlorine in the evenings.
    doc.mosi's Avatar
    Jun 2012
    Minnesota
    52
    That's what I started doing a bit ago...i was Still losing FC overnight.....but the pool is looking better than ever.
    I'm at about 15 of the 182Oz bottles of bleach so far.....
    Things I use daily:
    doc.mosi's Avatar
    Jun 2012
    Minnesota
    52
    So I'm now ready to change up the sand in the filter. After that I'll be adding some hth CYA crystals.
    Plan to continue shocking until CC are down and I pass the OCLT.
    Things I use daily:
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Have you already passed the OCLT? According to the baqua conversion instructions you must do that before changing out the filter media.
    doc.mosi's Avatar
    Jun 2012
    Minnesota
    52
    I have not....guess I'll have to wait a little longer to change the sand....
    Things I use daily:
  20. Back To Top    #20
    doc.mosi's Avatar
    Jun 2012
    Minnesota
    52
    I'm going back to read the Baqua conversion thread again.
    Things I use daily:
