Results 1 to 8 of 8
Thread: Pool Timer wont turn for pool sweep side only
    Dallas, TX
    227
    The Dial stopped moving on the sweeper pool pump timer. Any fixes for this? Do i have to replace both timers in the box?
    Looks alot like this:
    http://www.zorotools.com/g/00055245/k-G ... g_Feed&kw={keyword}&gclid=CLi-p7Dc0LACFVPftgodXyCjXA
    new house: TBDK gal IG plaster pool, filter Titan CM DE filter 36 sq ft , 1.5 HP Pump; Polaris 380
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pool Timer wont turn for pool sweep side only
    You can buy a replacement timer motor for it.
    A little better than halfway down the page http://www.poolcenter.com/timers_automation.htm
    Dallas, TX
    227
    DOES THAT REPLACE THE WHOLE THING INCLUDING THE MOTOR? HOW CAN I TELL HOW MANY VOLTS IT IS.
    I AM BUYING ONE FOR MY DAD TOO, HIS DOES THE SAME THING. HIS MOTOR SAYS MODEL WG433 AND IS 208/277V
    Or is the motor good since it will run when it is pushed to the right and this is just replacing the mechanism
    Dallas, TX
    227
    Still not sure if the fact that it doesn't turn is a mechanism issue or a motor issue. i can get anew motor for $18 at Grainger. Should i try that before replacing the mechanism?
    22,544
    It's almost always the motor when the dial doesn't turn. I'd try the motor first. You can try looking at the motor spindle gear and see if it's turning. Be warned that it turns very very slow.
    Dallas, TX
    227
    ok great thanks. picking up a motor at lunch. hope that works!
    Dallas, TX
    227
    That was it. Replaced the motor in 5 mins and working like new. Thanks for the help!
    22,544
    Glad it was an easy fix. And you didn't have to replace the whole timer.
