Thread: Pentair Solar Touch controller
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I currently have a solar heating system that has a controller with about a 10 degree variance. If your house thermostat worked like this thing, you would take a sledgehammer to it. The setting that turns on the heat at 79 wont turn off until its over 90. I'm looking for a digital controller with a much finer (2 or 3 degree) variance.
    The pentair solar touch seems like an affordable option. I'm wondering if any forum members have any experience with this unit.
    chiefwej
    Re: Pentair Solar Touch controller
    Nearly all of the solar controllers let you adjust the temperature range they cycle over. Or your current water temperature sensor might be mounted in the wrong place.
    The Hayward GL-235 is the best of the inexpensive solar controllers. The Pentair is also good, but noticeably more expensive, though it also does more.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    My current control is a Helio-Matic HM500D.. It only has a knob to adjust the temp and a three position slide switch, marked "test-on", "auto" and "off". The knob had markings from 70 to 95 and the instruction booklet says to calibrate use the set screw on the knob. No very high tech. Turning the knob I can see how far it is before I hear the relay click to turn it on and how far it is to hear it turn off and it's well over 10 degrees. The people who installed the system have replaced the controller twice,(due to a different problem) but I have never been satisfied with the lack of control over water temp.
    One reason I was considering the pentair unit was it is set up to control a VS or VF pump, if I decide to upgrade to one of their pumps in the future.
    I can get the pentair for under $250 including sensors and a three way valve with actuator. The price seems to be similar for the Hayward. Since I would only save about $40-50 buying the controller only, I thought it worth the extra to have spare sensors and actuator.
    chiefwej
    If you can get the Pentair for $250 then go for it. I haven't seen it for less than $340.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Thanks for the info.
    FYI: pentair solar touch control system 521632. $249.95 with free shipping at SunPlay.com
    http://www.sunplay.com/product-p/521632.htm
    chiefwej
