Thread: Ez touch relay for swim jet
    Anyone know which relay to use to control a 4 hp badu swim jet through an eztouch?
    Re: Ez touch relay for swim jet
    How many amps is it rated for and at what voltage? The listed HP doesn't tell the full story.
    Rated at 21.0-19.4 at 208-230v. My concern is current draw at start up with stock eztouch relays.
    May 2011
    Orange County, CA
    696
    You will likely need a beefier DPST relay to handle the load you are describing. You might check the Grainger website for a proper relay for that load.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    The Badujet has it's own controls. Mine is connected directly to a 50 AMP breaker. The system, at least mine, uses a air button that can be at the pool. Mine is at the pool wall. I'm not sure what system you have but the Badujet manual will tell you exactly how to wire it and of course you should use an electrician.
    Northeast PA (Mt Cobb) 16,000 gallon in ground salt pool with all Pentair automation and Intelliflo VS pump. Also part of the pool is a two 5-horsepower 3-jet Badujet swim system. For heating we use a 384 sq-ft Heliocol solar pool heating system and additional solar from the 160 sq-ft house solar heating system.
