Thread: bottom track rail question
    Looking at agp and trying to decide which is better, steel bottom track, or resin bottom track?....I have read that resin bottom tracks are harder to work with than steel ones, if so why..and why did you pick the one that you did...thanks for any info
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: bottom track rail question
    The pool wall simply sits in the track, one isn't harder than the other. If anything resin is easier as the bottom rails simply snap into the legs and don't need to be screwed in.
    There's people out there that contend that resin is inferior - it's not. I have a resin pool and the set up was great, it can endure a hard Canadian winter, won't rust and the parts are very strong.
    Resin pools are a great option if the added expense is within budget, I would highly recommend the upgrade, but if it's not in budget get what you can afford and have fun!
    i see you have a sharkline matrix, did you order that from poolsupplyworld?
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    FamilyPoolFun.com
