Thread: muriatic acid, this brand safe to use?
    Oct 2010
    michigan
    284
    http://www.wmbarr.com/ProductFiles/GMA58%20J5806.pdf
    is this brand safe to use? anyone use this miriatic acid? they sell this at lowes, but isn't on lowes webpage.
    it says do not mix with chlorine, but i'm thinking they mean directly to chlorine.
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Mar 2012
    Amarillo, Texas
    341
    Re: muriatic acid, this brand safe to use?
    Looks like the right stuff. They mean don't pour it in a bucket with chlorine. Fireworks may occur!
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    That's the stuff!
    The label even says 20° Baumé Hydrochloric Acid 31.5% By Weight.
    If that is in, say, paint department, or masonry, wander out to garden where the pool stuff is kept and check the price on the swimming pool brand. Then buy whichever one is cheaper.
