Thread: New cleaner.. now the install
    Jan 2008
    Austin, TX
    I was gifted a Hayward Phantom and booster pump for Christmas, but I have a dilemna. I have an inground vinyl pool, but I am not the original house owner and dont know who installed to pool. Believe it or not I have called 3 pool services about installing it, and nobody has called back (bad sign? they didnt even get to quoting me a price), so I might have to take it on myself. My dilemna is that it is an inground vinyl pool.. so should I:
    a) refit an existing return with the proper nozzle, run line from where it junctions with the other returns back to the pump at the equipment or
    b) drain the pool enough to get at existing return levels, and put in a new one (bothers me to try to put a hole in a 3 year old liner)
    Any sage advice??
    32x16 in-ground vinyl
    18,000 gallons
    Sand Filter, 1.5 hp
    One skimmer, main drain feed, 3 returns
    Auto Chlorinator (pucks,not in use)
    Using The Liquidator
    Austin, TX
    Jul 2007
    North of Dallas
    I say 'A' is the answer for you. But, who am I to know anything.
    My Pool - 18x24 fully setup Cabana, 22x48 gunite/quartz plaster (3-5-3 depth) & 8' spa w/ spill and 5' natural rock waterfall; Hayward DE filter/pumps/heater; Hayward Pro Logic controller; Phantom cleaner. Finished 06/01/07.
    make a new return or i think they make an over the wall kit i know that polaris used to have one
    you would use a garden hose to run from the equiptment to the pool and than elbow down into the water although having hoses around the pool like that people will step on it or trip over it
    so i would go with B
