Thread: Hayward Summit 2.5T showing DPC
    Hi guys,
    looking for some advice here,
    My pool startd flashing the DPC code this afternoon.
    I looked it up and it means : Suction temperature probe is short circuited or may be defective
    So I try to troubleshoot it but I can't find any info about it besides link to the owner's manual.
    Also, I don't have any idea which part has to be changed if it's defective.
    I thought it would be the suction temperature probe but there is no part with that name when I look it up on the hayward parts website.
    I'm trying to find how much it costs, how to change it and if I need a professionnal to come and have a look at it.
    If you guys can help me in any way I'd really appreciate it. Also, if someone could specify a part number or a part name that would fit this code, It would help me a lot.
    Here are the details: 21' above-ground pool
    salt water treatment (aquacell)
    Hayward summit water heater 2.5T
    Thanks!
    Re: Hayward Summit 2.5T showing DPC
    Ok...
    by searching more I stumbled on this : SMX306000024 Water Temperature Probe for Summit 2.5T
    By looking around, I found it to be priced between 20$ and 30$.
    How complicated is it to install a new one? Anyone tried it before?
    It is an easy replacement if you have good access to the old sensor. Before buying a new one, it is worth locating the old one and checking that the wire is still connected. Sometimes the wire simply gets disconnected, which is an even easier fix.
