Thread: Someone jammed a stick into the bottom of the pool
    I hope this post is in the correct place....
    We have an Intex 15X48 metal frame vinyl pool. Long story short, "someone" jammed a stick into the bottom of the pool near the side. The hole was about 1.5"X1.5". We patched with Boxer vinyl repair, doing a poor job as an inexperienced pool people. It leaked. We then drained the pool and pulled the old patch off....YIKES!....wrong thing to do! The hole is now about 5 inches long by 2 inches wide. We pondered this and decided to clean the bottom part (outside) of hole and apply patch there.....we did, with about 1/2 inch over the hole, set, then applied the same on the inside, set, then put a larger patch over that on the back (outside)...now we waited and decided to fill the pool to have the water 'shape' at the hole sight....we did and then patched the inside, under the water, 2 inches over the existing patch. We are now filling the pool more to see if it works. If there is a wrinkle under the patch, which there is, do you all think this will be compromised and the whole thing will fail? We are a praying people and have prayed over this whole trial....if it works great--if it doesn't, that's OK too. Thanks for any imput.
    22,553
    Re: Someone jammed a stick into the bottom of the pool
    Welcome to TFP.
    It all depends on the patch and the glue. Since you patched the outside and inside with more than one layer you probably stand a pretty good chance that it'll work and not leak.
    Good Luck
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    "Someone" needs to stay out of the pool. Good luck, hope it holds.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Apr 2012
    Prince George, VA
    33
    It's a good thing y'all are "a praying people and have prayed over this whole trial" otherwise "someone" may have had an encounter of a different kind with the stick!! I will add my prayer to yours that it all works out.
    Peace,
    Bill
    Barrier Reef Pacific1-Pacific color 37'9" X 14'1" fiberglass IG ~ 17,500 gallons, FHPM1.0-2 Jandy FloPro pump, Jandy Aquapure 1400 SWG, Waterco Multicyclone 16 pre filter, Jandy CV580 filter, 3 PAL-2000 RU LED lights, 1 skimmer, 2 main drains, 3 returns, 2" rigid pvc suction and return plumbing, BBB method, TF100 Kit
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    ^^ LOL. "Someone" on a stick.
    Thanks all. And I like the humor
    We have filled it about 1/4 and it is holding so far....praise God!
    The "someone" was given the opportunity to confess and be forgiven....but chose not to
    I don't think that was a wise choice...but....we all make the decision that seems best.
    Thanks again!
