Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
Thread: I still have a cloudy pool
  1. Back To Top    #41
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Re: I still have a cloudy pool
    This is the 5th year for the sand in the filter.
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
  2. Back To Top    #42
    22,553
    With your CH level there's not much possibility of calcification so don't worry about the sand.
  3. Back To Top    #43
    deleted
    18'x36' In Ground Vinyl
    Depth: 3'-5'
    Skimmer & Main Drain
    Hayward Sand Filter, Pump & Spider Valve
    TFP System: Chlorine
  4. Back To Top    #44
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    How often should the sand be changed?
    Installed May 2011
    BBB method
  5. Back To Top    #45
    22,553
    The only time the sand should be changed is if it's heavily calcified. It doesn't wear out like the pool store says it does.
  6. Back To Top    #46
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Good. Have I mentioned lately how much I love this site????
    Installed May 2011
    BBB method
  7. Back To Top    #47
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,109
    Quote Originally Posted by poolmama67
    Received my K-2006 test kit. Check the chlorine levels at 9:05 last night:
    FC-8.5
    CC-.5
    Check all the levels this morning at 8:15 am:
    FC-8
    CC-.5
    PH-7.4
    TA-100
    CH-90
    CYA-20 or less-could still slightly see the black dot with the tube completely full.
    I have granular shock. Can I raise my CYA using that?
    Back to the op's issue. The vast majority of the time, cloudy water means dirty water. Most often water full of algae, or dead algae. Bring your CYA level up to 30 and start shocking. The quicker you do this....the quicker the pool will clear up. Have you tried the OCLT yet? This too will show you JUST how much chlorine your pool is using to fight off any garbage that's living in your pool.
  8. Back To Top    #48
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Posted on the 27th that water was clear. Water is still clear and I am keeping a close eye on my chlorine levels as to forego any future algae issues. I test daily with test strips and at least weekly with the K-2006 kit.
    Installed May 2011
    BBB method
