Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 48
Thread: I still have a cloudy pool
  1. Back To Top    #21
    toadlife's Avatar
    May 2009
    Lemoore, CA
    57
    Re: I still have a cloudy pool
    Quote Originally Posted by poolmama67
    So I take it that the HTH test kits are worthless?
    The HTH test kits (the "OTO" one) are not worthless. The limitation they have is that they only test total chlorine instead of free chlorine and combined chlorine and they only test up to 5 ppm chlorine. To test above 5 ppm with the test kits that use the color matching, you have to dilute the sample with water that has no chlorine (preferably distilled water).
    I got by my first year of BBB with one of those 6 way HTH OTO test kits from Walmart, but have since moved onto a Taylor K2005 + Taylor FAS-DPD Chlorine test, which together is a roughly equivalent to the TF-100 test kits everyone here mentioned has all of the tests.
    I would recommend getting a TF100, or a Taylor K2006. I made a mistake in buying the K2005, which is why I had to buy the FAS-DPD test separately. I also recommend the "Speedstir" as mentioned above. I ordered one with my FAS-DPD test kit and it makes doing the drop by drop test MUCH easier.
    If I had it to do all over again I would have just bought a TF100 or Taylor K2006 in the first place, but I didn't find TFP until after I had cleared up the swap that came with my house.
    21,000 Gallon IG Plaster with Spillover Spa (Built in 1978) | 48 sq/ft Hayward DE Filter | 3.0 HP Pentair Variable Speed Pump | Hayward H250FDN Heater| 8 Gallon Liquidator | Taylor K-2005 | Taylor FAS-DPD Chlorine Test | Taylor "SpeedStir"
  2. Back To Top    #22
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Pool water is cleared up now. Was able to enjoy the water and swim today. I have read the pool school information. That's a lot of information so I will spend more time re-reading the information and I have also ordered the test kit recommended. Testing water every day with the testing materials that I have at the moment so that the water doesn't get out of hand again. I have family coming in next week and are looking forward to some pool time. Again, I am so glad that I found this site and will not go back to the pool supply store.
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
  3. Back To Top    #23
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Good to know. What was it that ultimately cleared up the water?
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
  4. Back To Top    #24
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    I flocked the pool and then vacuumed it to waste. I then balanced the water again. Not had anymore trouble since then. Using the BBB method and it seems to work great.
    Installed May 2011
    BBB method
  5. Back To Top    #25
    Mar 2007
    San Rafael, CA USA
    12,082
    For our records, what brand and product name of floc did you use?
  6. Back To Top    #26
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    HTH Green to Blue kit
    Installed May 2011
    BBB method
  7. Back To Top    #27
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    water going cloudy again. Did test with HTH 6 way test kit from walmart:
    TC-1
    PH-7.2
    CYA-unsure as I could still slightly see the black dot at 30
    TA-110
    TH-0
    Adding fresh water to attempt to bring CYA down. And add 2 jug (186 oz) of bleach (6%)
    any further suggestions would be appreciated.
    Hoping K-2006 test kit comes in tomorrow or Tuesday.
    Installed May 2011
    BBB method
  8. Back To Top    #28
    Mar 2007
    San Rafael, CA USA
    12,082
    A 1 ppm chlorine level is, of course, too low. And we don't even know if that or the CYA level are the right amounts. We'll know soon once you get the K-2006.
    Why are you trying to get the CYA down if it seems like it's less than 30? If the CYA level is really that low, then that will have the chlorine drop faster in sunlight. If you are there staying on top of the pool adding chlorine regularly during the day, then a low CYA level would be OK and let you kill off algae faster, but otherwise you'd want it a little higher, probably 40 or 50 ppm.
  9. Back To Top    #29
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    So if I need to raise my CYA, I have to buy stabilizer right? Still not received test kit. Checked on status-shipped with no tracking information.
    Tested water this morning and concerned about the CYA level as it is still the same and ph is 7.2. Is the PH ok?
    Installed May 2011
    BBB method
  10. Back To Top    #30
    Mar 2007
    San Rafael, CA USA
    12,082
    Focus on your chlorine level right now. Get that up higher to prevent an impending algae bloom. Use chorinating liquid or 6% unscented bleach.
  11. Back To Top    #31
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Chlorine level is up and water is clear again. Maintaining chlorine of 4-5 and checking the levels twice a day.
    Installed May 2011
    BBB method
  12. Back To Top    #32
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Received my K-2006 test kit. Check the chlorine levels at 9:05 last night:
    FC-8.5
    CC-.5
    Check all the levels this morning at 8:15 am:
    FC-8
    CC-.5
    PH-7.4
    TA-100
    CH-90
    CYA-20 or less-could still slightly see the black dot with the tube completely full.
    I have granular shock. Can I raise my CYA using that?
    Installed May 2011
    BBB method
  13. Back To Top    #33
    Butterfly's Avatar
    South Carolina
    10,045
    If it is dichlor or trichlor, yes.
    If it is cal-hypo, no. Cal-hypo raises CH.
    You're done SLAMing when:
  14. Back To Top    #34
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Thanks Butterfly! I soooo love this site. My husband is like, "don't you ever get off that site?" LOL
    Installed May 2011
    BBB method
  15. Back To Top    #35
    Butterfly's Avatar
    South Carolina
    10,045
    Oh, yeah. I KWYM It's addictive!
  16. Back To Top    #36
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Ok. I only have the cal-hypo shock so I can't use that. What do I need to add?
    Installed May 2011
    BBB method
  17. Back To Top    #37
    Butterfly's Avatar
    South Carolina
    10,045
    To raise the CYA, add cyanuric acid, (also labled as stabilizer or conditioner). Ingredients should be 95ish % cyanuric acid. You can get a jug at wallyworld, pool store, big box store, etc. The wallyworld is reported to be more powdery and dissolves faster.
  18. Back To Top    #38
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Ok. Thanks again Butterfly!!!!!
    Installed May 2011
    BBB method
  19. Back To Top    #39
    Butterfly's Avatar
    South Carolina
    10,045
    You're welcome. Use the PoolCalculator to determine the correct dose
  20. Back To Top    #40
    deleted
    18'x36' In Ground Vinyl
    Depth: 3'-5'
    Skimmer & Main Drain
    Hayward Sand Filter, Pump & Spider Valve
    TFP System: Chlorine
