Thread: Couple of testing questions.......
    Mostly curious about FC testing with the TF-100. I understand the extended test results for getting testing down to .2 ppm, but is it possible or wise to save on regent and test for higher levels? Such as using 5 ml of water...would that make each drop of regent value be 1ppm?
    And....can you test for CC WITHOUT testing for FC first?
    Haven't seen this covered and wanted to get a "professional" opinion!
    Thanks!!!
    16,000 IG, SWG, 175 sq. ft. cartridge, 1.5 hp pump, vinyl, Charlotte NC
    TF-100, Pool School, Pool-Calc
    Aug 2010
    Dallas, TX
    4,052
    Re: Couple of testing questions.......
    Don't bother with the .2 ppm tests. Your pool doesn't require that kind of accuracy. You have to run the FC test to get your CC numbers.
    If you just need a basic idea of where you are at, use the DPD test, the one where you match it to the color blocks. I don't use my FAS-DPD every day.
    Montreal Canada
    326
    Quote Originally Posted by samiguy
    Yes. However the margin for error would be much greater, the smaller the sample size the bigger the error.
    Was curious because at high shock levels (28ppm), was looking for a way to check often without using so much regent. Obvious OTO is not a solution here. Haven't seen it cover and wanted to ask.
    Montreal Canada
    326
    It all depends. A 10% error in measuring 5 mL of water sample is significant (and it affects the end result), whereas a 10% error in measuring say a 250 mL is insignificant.
