Results 1 to 12 of 12
Thread: Ph staying high
    Ph staying high
    I lower my ph than My ta goes down , so I have to raise my ta back up using baking soda , than my ph goes up. I feel like I'am going in circles.
    30,431
    Re: Ph staying high
    Welcome to the forum. You are going in circles.
    Read the article in Pool School on how to permanently lower TA without lowering pH.
    Re: Ph staying high
    What are you keeping your TA at right now? Chances are you are maintaining TA at too high a level, which is what is causing the PH to rise.
    Re: Ph staying high
    Thanks for the help , One more question is does adding bleach raise ph . I do not have any borate in my pool.should I add borate because I'am using bleach and baking soda but not borate.
    My water readings
    Ta 60 - 90
    Ph 7.5 - 7.8
    Cya 60 - 70
    Ch 1.5 - 2
    Thanks
    Re: Ph staying high
    Let the TA settle around 60 and only raise it back to 60 when it goes below 60.
    Bleach doesn't cause any net change in the PH. Adding bleach raises the PH for a short while, and it then goes down again as the chlorine get used up.
    If "Ch" is chlorine, your chlorine level is too low. With a SWG, you should keep FC at 3 or higher. Without a SWG it should be 5 or higher.
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Re: Ph staying high
    So you are saying that you have a LOW TA, but your pH keeps rising? Does it get above 7.8 or is it stable there?
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
    Re: Ph staying high
    Thanks yes ch is chlorine . No SWG system just chlorine pool are you sure on have FC at 5 that seam high . That my be why I always have some problem because I always was told not to go above FC 3. Should I use borate or not I have read about it ,some say yes and some say maybe ??
    Aug 2010
    Dallas, TX
    4,052
    Re: Ph staying high
    Borates can help stabilize your pH swings, yes.
    And yes, your chlorine level depends on your CYA level. All that talk about don't go over 3 is, for a lack of a better term, BS.
    Re: Ph staying high
    My ph is stable around 7.5-7.8 and my ta is stable to, how can I low ph with out lowing ta ?? or should I just let my ph still at 7.8 .
    Re: Ph staying high
    Just let your PH sit at 7.8.
    Aug 2010
    Dallas, TX
    4,052
    Re: Ph staying high
    7.5 to 7.8 is where you want to be!
    Re: Ph staying high
    Thanks for the help
