CYA Testing Question
Glock30
0
92
Massachusetts, USA
I have read in Pool School that CYA may not show up in testing until a week or so after adding.
Is this only if you slowly dump it into the skimmer allowing it to dissolve in the filter or is it true even if you dissolve it with the skimmer sock method?
Thanks
Hi Glock30:
When you pour dry CYA directly into the skimmer, much of the dissolving will take place within the filter.
When I add CYA, I use the sock-in-the-skimmer method. Much of the dissolving takes place within the sock (although I give the sock an occasional squeeze to help things along). When I squeeze the sock and no cloudy residue appears, then I know that my dose of stabilizer has been added. I have re-tested within 2-3 days of the sock being empty and my CYA has increased to what I was targeting. Subsequent confirmation testing has revealed that it has held steady. However, the total elapsed time from first placing the CYA-laden sock into the skimmer and testing is still about 5-7 days. So using either application method, 5-7 days from first adding the CYA to testing for it is a good rule of thumb.
