Thread: Max "overhang" for concrete pool deck (vinyl pool)
    Ottawa, ON, Canada
    153
    I've had some issues with the concrete deck near my diving board. It was installed with a sonotube to offer extra support but it appears that because of it the concrete was lifting with the frost thus it cracked pretty badly. The poolbuilder offered to fix this and work is now in progress as shown in the 1st picture. I however have some concerns with the amount of concrete that will have to be supported by the pool "brackets" (seen in the 2nd picture, before their base was covered in concrete): can they really handle ~4 ft wide of concrete? They are made to take the weight of the deck (my deck is 36") but I've got certain concerns.
    The new concrete guy working with that pool builder seems to know his stuff way better than the guy who did my pour and he says that a sonotube would only make things worse (ie: as what happened in the 1st place) but all I see is a big cantilever and I'm concerned that it may cause the pool wall to deform.
    Any thoughts?
    19.5k gallons in ground, P4 panel with turbocell SWG, 1hp Hayward superpump II, sand filter, Heater low nox 250k btu heater, solar cover on rocky roller
    Re: Max "overhang" for concrete pool deck (vinyl pool)
    The concrete will be supported by the dirt under the concrete, not by the brackets which support the wall. If there was going to be a problem with the brackets interacting with the concrete it would have already happened around the rest of the pool.
    Ottawa, ON, Canada
    153
    Woops, I've just realized that my reply never made it. THanks for the info Jason, I thought that the deck was mostly supported by the brackets since they are called "deck support" when you look at the Kafko litterature (My pool isn't kafko but similar)
