Thread: New Pump
    Nov 2011
    Lewiston Idaho
    76
    New Pump
    Hi All,
    Ordering a new pump motor tomorrow. The old one is making more and more noise.I have a 1 1/2 hp Sta-rite pump. I also run a caretaker system and am thinking of just replacing the pump with a EE unit.
    Is there a big advantage to getting a 2 speed motor? I have searched and read threads and end up confused. I am running a timer and have the filter running two 4 hr shifts. Keeps the pool pretty clean. We are dropping a large pine tree in a few days which should really cut down on pool debris.
    We are in a area with pretty reasonable electricity rates. around .08 per KWH.
    With the caretaker system will a 2 speed with the lower rpm work?
    Any recommendations on a place to order or to avoid?
    Thanks
    Phil
    18,000 gallon in-ground plaster pool. Sta-rite cartridge filter, Sta-Rite Max-E-Glas II pump 1 1/2hp motor, Caretaker pool cleaner, Teledyne LAARS series 2 ESC natural gas heater 250,000 BTU. Solar Pool cover, Intermatic Timer with heater switch. Two very happy kids!
    Re: New Pump
    There is normally a large savings in electricity when you get a two speed pump. However, the caretaker system will not work on low speed, so you can only take advantage of the savings of low speed when not using the in floor cleaning system.
