Results 1 to 7 of 7
Thread: Pristine Blue user. I have an issue with mineral staining
    I'm new, so sorry if this is old news. I am a Pristine Blue user. I have an issue with mineral staining on the floor of the deep of my vinyl lined in-ground pool. Last year I used the product above (sparkle conquest) with great results. This year, did the same thing and while it seemed to fade, now after a few weeks, its just as dark as before. My water balance is spot on so its frustrating that this keeps happening. I have another bottle of Sparkle Conquest but dont want to put it in if after a couple of weeks the stains return. I contacted Pristine Blue folks and they say Pristine is copper based so using sparkle is taking out the copper and using Pristine puts it right back in. I am on city water so I do not beleive its a metal issue from topping off. Any other Pristine Blue users experience this issue and how do you resolve it? thanks Coop
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Pristine Blue user. I have an issue with mineral stainin
    The only way to resolve it is to stop using Pristine Blue. It stains pool surfaces and bathers' hair, and doesn't sanitize the water safely. It has no real benefit except as an algaecide, and it has the drawbacks detailed above.
    Feb 2008
    Denton, TX
    5,061
    Pristine blue is adding metals to your water. This is what is staining your pool surfaces.
    Sparkle is a sequestrant. Sequestrants normall bind to the metals and prevent them from staining, but do not remove them from the water. The sequestrant breaks down eventually, and unless you add more sequestrant, the metals get released back into the water where they can form stains again.
    Ok.. get this.. This weekend I put Pristine Clean followed immediately by Pristine Extra. I walked away to put chemicals back under the deck and when I walked back, the stain was nearly gone. As I watched, the stain totally vanished. I don't know why it didnt work like this before, but it certainly worked Saturday. Maybe balance was just right for stain removing action. Now it seems as pool season is officially running smoothly. About darn time !!
    Feb 2013
    Southwest Jersey
    1
    I am glad to hear of another Pristine Blue user. I just bought a 52x15 above ground pool and Pristine Blue was recommended so we took it. I am hoping we made the right choice. I hope it disinfects as promised. How long have you had your pool?
    Quote Originally Posted by POOL13107
    About 12K gallons, cartridge filter, in-ground plaster.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by msmusco
    Pristine Blue does not disinfect, period. Read the label, assuming you have the newer bottles where Pristine Blue had to change what they claimed. They were in violation of strict EPA FIFRA regulations that say that a pesticide product cannot claim to kill bacteria in swimming pools unless it passes the stringent EPA DIS/TSS-12 test. Copper ions alone simply won't cut it since they do not even kill fecal bacteria (see this link for technical details).
    So you have to use chlorine so why bother with the Pristine Blue? The metal ions can just end up staining plaster surfaces.
