Thread: new intex sand filter loss of suction
    I just purchased an intex SF20110 sand filter this year and it seems to loose suction/prime when I try and use the surface skimmer. I also have had a dickens of a time keeping prime while vacumning it. Any suggestions? I hate not to use the surface skimmer as it does seem to do a very good job keeping the bugs / debris and such off the top of the pool water.
    Intex 18 x 52 Ultra Frame Pool Set
    Intex Model: 54955
    Pool Size: 18 ft x 52 in
    Water Capacity (90%) - 6,981 gal.
    sand filter 2100 gph
    Oct 2011
    New Caney, Texas
    414
    Re: new intex sand filter loss of suction
    Welcome to the forum
    Did you make sure that the skimmer is well below the water? You don't want it forming a vortex as it will suck air. On the vacuum make sure that all the air is out of the hose by placing the end over the return to force all air from the hose prior to connecting it.
    Remember to unscrew the skimmer hose adapter from the intake now and then as things that make it past the skimmer will sometimes clog the intake screen.
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    thanks for the advise, the skimmer is well below the water, and I did make sure there was no air in the vacumn line. I can get it to start off very well, but then it seems as if the filter is too strong almost and not able to draw in water fast enough, so it looses prime. If I remove the surface skimmer from the eqation it works fine, the preasure stays in the green section on the dial, but with it hooked up or durring vacumning it has almost no pressure.
    Intex Model: 54955
    problem solved, I noticed a slight hiss at the inlet vaulve, found a broken o-ring, replaced it now it is good to go
    Intex Model: 54955
    Oct 2011
    New Caney, Texas
    414
    Good to hear
    I am having this same issue however I have not found a broken seal and can't figure out what the issue is to save my life! I have watched and re watched the installation video and at one point it says to remove the grid cover from the outlet connector but my outlet connector appears to be one solid piece.......
