Results 1 to 13 of 13
Thread: Deck design - what to do and what not to do; that is the ?
    TonyM's Avatar
    May 2012
    Middle Tennessee
    85
    I bought a house last year that came with an above ground pool. Found this place and have successfully turned my swamp into an oasis. I am a graduate of the pool school and I am a fan of BBB.
    Now that I am past this stage, I gotta give the wife a place to put her chair. Its deck time.
    The pool currently has grass, weeds, rocks and an attempt at a concrete paver patio. All of this mess has to go. The previous homeowner (husband) did not want the pool (according to his wife), and put no effort into the area around the pool, at all.
    I have read through the forums and have seen several great projects, as well as some neat extras that help to increase enjoyment.
    What I want from this thread is some feedback on 'must-haves' or 'wish-i-had-done-this' or the 'be sure to not do this' from builders or owners of AGP decks.
    I am experienced with deck building, so no option is off the table (within budget).
    Right now, I am thinking I will deck about 25% of the pool, approximately 16'x16'.
    17k gal, Swim Pro Sand filter (Filt. rate 25gpm/ft^2, Flt/BW 80gpm), AG, Vinyl, 1HP Haywood power pro LX pump (60gpm), TF-100 Test kit, Speedstir
    Carl Spackler: "You got a pool over there?"
    Ty Webb: "We have a pond in the back. We have a pool and a pond. The pond would be good for you."
    Sep 2009
    Greentown, IN
    914
    Re: Deck design - what to do and what not to do; that is the
    When we built our deck it had to work as our fence too to meet code. We couldn't afford to put a privacy fence up around the entire area, and had to have a 6ft fence around the pool with a self locking gate. We chose to build a narrow walkable deck around the perimeter of the pool and at one end we have a nice size sitting area.
    I wish we had made the opposite side of the sitting area larger so we could have had a solar cover reel at that end. Now we roll the cover onto it's reel in sitting over the center of the pool & have to lift the cover to sit on the railing that is around the walkway when we want to use the pool. A bit of a feat for me... DH has no trouble with it though.
    It looks like you live a bit further south, so you may not have as much need for the solar cover. We use ours most nights w/the exception of the heat of late summer, just to keep our temps where we like to swim... low to mid 80's. We're in central Indiana.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    deweypip's Avatar
    Jan 2012
    Richland, PA
    115
    We just put up a 24' AGP. My deck design is approx 27X27. Takes up about 1/3 of pool diameter. Personally I'd like it bigger. Budgetarily(sp??) it will have to do.
    Point is---build it as big as you think you need, or to what you can aford. Too big won't be a problem, too small will be.
    24x54 Sharkline Matrix
    Hayward 1 hp Powermax single speed pump
    Hayward ec50ac DE filter
    Jun 2010
    San Antonio
    424
    I agree too big will not be a problem. My only suggestion is to consider future maintenance on the pool. When I had to replace some broken rail caps I had to demo part of the deck to gain access. A better original design would have made it easier.
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    How many people will be on your deck?
    Add to that: tables, chairs, pool toys, room for horseplay, etc.
    A 16x16 deck will suit a small family and is enough for a few kids to play on, we have a 20x12 deck, with a 4 seat table/chair set and a few adults it fills up fast, I wish I had room for 20x20.
    Jun 2012
    western NY
    1,562
    Here is how I handled mine. Did not want or need too big of a deck but wanted something more than just a square blob on posts. I designed this as a modular system and can add more pie sections should I ever want to.
    When I built this I took some ideas and lessons from friends who had pools. One thing I did not like about some pools is the framing of the deck built over the top of the pool rail. What I mean by this is the 8" framing as well as the decking hovering over the top of the rail. I also saw what happened to the top rail on my friends pool when he built his deck level with the top of the rail. All three rail sections the deck is around are completly trashed after two years of use. I went with what I determined to be the best alternative and that was to fit the deck so it is only a couple of inches over the rail. It, to me, does not look so imposing and still protects the rail. Both pie sections were framed separatly on the ground and are exactly the same framing configuration. Both deck sections to this day simply sit on top of the framework rails and can be moved if needed. The stairs are mounted to heavy duty hinges and can be folded up when not in use. When I first built them I thought they would be too heavy but, my wife can lift them with realtive ease.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    TonyM's Avatar
    May 2012
    Middle Tennessee
    85
    Quote Originally Posted by Suziqzer
    True - but I hadn't thought about that. I might look at building this capability into my design, just in case I want/need it in the future.
    Quote Originally Posted by deweypip
    build it as big as you think you need, or to what you can afford. Too big won't be a problem, too small will be.
    Good point. My line of thinking was just a few chairs and maybe a small table - maybe I will go to 1/3 or 1/2...
    Quote Originally Posted by Txmat
    This is my biggest design question - where to put the deck in relation to the pool rail. Over? Flush? Under?
    I like over (with the deck boards only) to keep people from standing on the top rail, but I am concerned with maintenance down the road. I am looking at a method (similar to danpik's post), where I can remove the deck near the pool for maintenance or liner change.
    Quote Originally Posted by cramar
    I would say that the most people regularly on the deck at one time would be 4 - 6 adults. When kids are there, obviously that would increase that number, but they can put their chairs in the yard
    Quote Originally Posted by danpik
    That is exacly what I am doing now. I want to take all of these ideas and build the right deck first time around. I really like the "birdsmouth" cut over your rail. Is it sturdy (standing on the edge)? If I put my deck "over" I only want the thickness of the decking over the rail, or as close as I can get to that height.
    Jun 2012
    western NY
    1,562
    Quote Originally Posted by TonyM
    No problem standing on the edge. I weight 250 and there is no deflection when I stand on it. There are actually 5 rafters under each pie section counting the two outside rails.
    Here is a picture of the overhang.
    TonyM's Avatar
    May 2012
    Middle Tennessee
    85
    ok - After vacuuming last night, I spent some time studying the area. I am bumping up the size based on recommendations here, but I will have to sneak in some lumber as the wife is the one with the hard budget ceiling .
    What size are you considering now? We're just getting the pool this week so dreaming of a deck is just in its infancy. What size pool are you putting it around? I will eagerly watch how this thread progresses, I love the way you phrased the question! So much knowledge to be gained here
    Vogue Vectra 30' Round (21,200 gallons), Waterway 2HP 2-speed, 27" sand filter - TF100 -- Southern IL - Install 06/2012
    Last minute upgrade from 27' due to error in dealer inventory *yikes*
    TonyM's Avatar
    May 2012
    Middle Tennessee
    85
    27' round. I am now thinking 1/3 of the pool, with a larger area for chairs and a table. Right now, the area around the pool is a mess. Patio pavers and weeds everywhere. I am going to post some progress pictures to this thread as I start building it.
    I'll be watching this!! When you say a 1/3 do you mean like 28 feet? Just curious as we've been trying to visualize deck sizes. Best wishes with it.
    TonyM's Avatar
    May 2012
    Middle Tennessee
    85
    I'm thinking 33% of the circle will have deck to the edge, with a 'rectangle' shape (as if the pool was eating into the rectangle-shaped deck). My pool is partially buried on one side (hill) so the deck will be over the buried part. This will make the cost less (lower to the ground - save on some posts).
