Results 1 to 7 of 7
Thread: CC level
    tcat's Avatar
    May 2012
    Austin, TX
    731
    CC level
    What's the best way to get an accurate CC level? Using TF-100, it says to "multiply the number of drops by 0.5 to get your CC level"... so only 1 drop would be a CC of .5, the max to determine if you need to shock or not. Is there a way to test between 0 and .5? Can't really had a half drop...
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Samantha_in_AL's Avatar
    Apr 2010
    Altoona, AL
    242
    Re: CC level
    Increments of 0.5 are the closest CC reading you can get. Ideally, you should have 0 CC.
    AG 18' X 52" Round Pacifica Pool w/ Metal Diamond Unibead Liner. Installed in March 2007.
    2.5 HP Baquapure 2 Speed Pump, 200 GPM Waterway ProClean Cartridge Filter System.
    Former Baquacil user
    Converted to BBB in Fall of 2009 - Now I have a truly trouble free pool!
    Re: CC level
    You do not shock when CC is 0.5. You shock when CC is higher than 0.5.
    There is a way to test CC more precisely, see the extended test kit directions, but there is no reason anyone with a residential pool would ever need to do that.
    Jun 2010
    Glendale, CA
    513
    Re: CC level
    If you really care you can run the test with a larger sample size. So for a 20ml sample each drop would be .25ppm
    But there really isn't any need to. From time to time you'll register a little CC. As long as that 2nd drop clears it - figure you are fine unless you have other reasons to think you are not.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Re: CC level
    Thanks! Just thought "shock over .5" seemed a delicate balance... so 1 drop don't worry, 2 drops shock? Clears with 1 drop, was just curious if would clear with 3/4 drop... or if it clears with 2 drops, is it's like CC of .75, if so, shock?
    DIY chlorine feed
    BBB
    Jul 2011
    Perrysburg, OH
    88
    Re: CC level
    If my CC test turns a little pink, I just add chlorine to get to the top of my normal pH range. By the next day, it always stays clear like normal... Don't seat it, enjoy!
    16 x 32 inground vinyl pool (21000 gallons) (new liner installed 2014)
    Hayward max flo pump w/ 1 HP AO Smith motor (new motor 2014)
    Hayward C1200 cartridge filter (new 2014)
    Hayward H150 heater
    Re: CC level
    Anything, even ever so slightly, above 0.5 means you need to lower the CC. Normally that should be done by shocking the pool. In an outdoor pool CC shouldn't ever go that high unless something is obviously wrong.
