Thread: Ordered TF-100
    Jun 2012
    Hudson Ohio
    47
    Ordered TF-100
    Just got my TF-100 test kit today. Can't find how to test for Borates.Filling out the pool calculator and it is asking about borates. Am I missing something? Results are FC= 4.5ppm PH=6.8 TA =320-never turned red-More of a pink color CYA=0
    18 x 54 Sharkline Matrix pool. 7800 gallons.
    Pentair Optiflo 1 1/2 HP 2 speed pump
    Pentair Clean and Clear 150 Sq Ft cartridge filter
    Hayward H100ID Heater. Purchased all from Poolsupplyworld. TF-100 TEST KIT
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Ordered TF-100
    Borates are optional and most folks do not add borates to the pool.
    Also, the borate test is sold separately.
    You need to get the pH up in the low to mid 7's ASAP using borax.
    What is CC?
    You're done SLAMing when:
    Jun 2012
    Hudson Ohio
    47
    Re: Ordered TF-100
    CC=0
    Feb 2012
    Phoenix, AZ
    728
    Re: Ordered TF-100
    You also might want to consider getting some CYA in your pool
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Ordered TF-100
    Yep, after you get the pH up to 7.4ish, add enough CYA via sock method to get to about 30 PPM.
    38,305
    Re: Ordered TF-100
    Note that the CYA may also drive your pH back down, so be ready to bump it up again. (assuming you use the solid CYA)
