Thread: Figuring out a new pump for a repo'd house
    Hey guys,
    First, I'm going to just apologize for my ignorance. I'm 100% COMPLETLY new to the entire pool thing. I purchased a HUD house in the winter that I've been remodelling. After several days of pool cleanup - I'm trying to get it going, but my pump is dead. After pool cleanup, repainting, and some plumbing I kicked the pool on. The motor sounds "stuck". Following what advice I could find online I've
    . Replaced the thing on top of the motor that goes out sometimes (can't remember what it's called)
    . Beat on the motor
    . Made sure the shaft wasn't locked up - I can turn it with my hand.
    I'm jumping to the conclusion that I need a new pump. I'm looking for something inexpensive, actually, downright cheap due to some stuff going on. Will this work? http://www.doheny.com/poolsupplies/Clea ... 7AodexM-XA
    Here is the info I could think of to provide. Anything I missed, or I need to provide more info on let me know, and I'll get it.
    . The old pump motor was Franklin Electric 1HP - https://www.dropbox.com/s/ijwsb5aras7u9 ... .59.55.jpg
    . Pool is 10 - 20 years old
    . The pool is in ground plaster
    . Deepest side is 5 ft, shallow side is 2.5
    . Sand filter
    . Here is a pic of the pump\filter\plumbing setup (sorry for quality) - http://i664.photobucket.com/albums/vv5/ ... icture.jpg
    . Here are some pics of the pool
    https://www.dropbox.com/s/ft06y0ovyxvct ... .23.08.jpg
    https://www.dropbox.com/s/pxs98mo3u10ac ... .28.13.jpg
    Re: Figuring out a new pump for a repo'd house
    Welcome to TFP!
    Depending on how much of a DIY type you are, you might want to replace just the motor and keep the wet end of your current pump. That is a little more work, but will allow you to get a better result for the same price. Otherwise, the pump you linked to is alright.
    Thanks!
    Could you point me in the right direction of a new motor? I failed to mention - the bottom of the housing that fills with water leaks. I can't decide if silicone would fix it or if the pressure would just push it out....
    May 2009
    Youngsville NC
    395
    If the wet end is leaking - get a replacement pump.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    You could also look for a used one on Craigslist. I got 2 Hayward motors with pump attached for $35. Hard to beat that.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
